No function from Digital Recepcionist/Access to Voice Mail
Discussion in '3CX Phone System - General' started by jaywar, Apr 25, 2010.
  1. jaywar
    Dec 10, 2008
    None of the configured Digital Recepcionist settings or when calls are transfered to the voice mails are working. We've restarted the server and all 3CX services but that still did not resolve matters. These settings where running fine until later this week.
    Our phones are set so that after working hours they go directly either to Voice Mail or Digital Recepcionist. Any idea what might be causing this? We get an error message saying that there was an error with the IVR session.
    10,375
    231
    You might want to post a 3CX log (verbose) of a failed call. If all was working well, up to a point, what changed at that point? Software update?
  3. jaywar
    Dec 10, 2008
    Thanks leejor. There is reliable 3CX support where I'm from and the two vendors do not provide the expected support. As an end user, I have to fend for myself with the limited knowledge that I've acquired on my own.
    I guess that log would be accessible from the server where the 3CX is installed? Nothing has changed since last week when all was working fine.
  4. jaywar
    Dec 10, 2008
    here is what i found:
    12:57:05.137 [CM503008]: Call(18): Call is terminated
    12:56:59.371 Session 128815 of leg C:18.1 is confirmed
  5. leejor
    10,375
    231
    Looks like you found the logs. Under Settings/Advanced, you can change the logging level to Verbose, which may give a bit more info as to why the call is terminated. You may have to restart 3CX to have that take effect. If you post the logs again start them earlier, from when the call starts
  6. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Your IVR is failing for whatever reason, the Server logs that are availble on the interface are not going to show the issue easily. I suggest you being from this link .http://www.3cx.com/blog/docs/troubleshooting-iis-ivr/ Please note it works for both IIS and Cassini. however you must ignore the IIS solutions if you are using Cassini.
