No G729 codec
Discussion in 'Windows' started by Deepest, Jun 3, 2014.
  1. Deepest
    Nov 9, 2012
    45
    Hi I have noticed there is no G729 codec in the new windows or android client.
    I seem to remember it being there on earlier v12 clients.
  2. roland_3CX
    roland_3CX Support Team
    Mar 28, 2014
    131
    7
    Hello Deepest,
    You are correct, it is not there. It was not on the previous version either.
  3. leejor
    11,079
    324
    G729 is patented and licensing fees usually apply...https://en.wikipedia.org/wiki/G.729
