no HTTP login*Fixed
Discussion in '3CX Phone System - General' started by FITEC, Jul 28, 2010.
  1. FITEC
    Sep 15, 2008
    19
    upgraded from V7 to V9 and encountered the error that login via http://localhost/management is not possible: after entering admin and password the same screen appears - Windows Management Console works fine. Any ideas?
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Re: no HTTP login - Windows Management Console OK
    Hi, we need more specific details -
    Can you check event viewer for any errors?
    On v7 what web server where you running?
    Also can you send me your backup of v7 which you restored on V9 to mb@3cx.com.
    Thanks and regards
  3. FITEC
    Sep 15, 2008
    19
    Dear Michael,
    thanks for the fast reply - just noticed that this behaviour occurs also on a fresh install (IIS7/SBS 2008)!
    Regards
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    You need to check for the following -
    1. Security Enhanced Enabled - Should be disabled.
    2. Clear Cache - Delete all cache from the system (due to corrupted cache).
    3. Restart IIS -
    4. Install latest Updates - and a restart of the machine is required too.
    Thanks and Regards
  5. FITEC
    Sep 15, 2008
    19
    Dear Michael,
    everything has been checked and it's still not possible to login via HTTP on a SBS 2008 (myPhone works fine)
  6. FITEC
    Sep 15, 2008
    19
    ...it turned out that the web.config was the problem - took a copy from different installation and voilá: login possible
