- Joined
- Oct 26, 2012
- Messages
- 13
- Reaction score
- 0
I have really been hitting my head against the wall on this one. I simply can not figure out what may be causing this issue.
Symptoms:
We installed a new router the other day. Calls were tested AFTER the installation and confirmed to work. There were no apparant issues.
This morning, any kind of call (outgoing or incoming) did not have any sort of inbound audio. Could not even hear the ringing tone. However, the calls -are- placed and people can pick them up.
Extension to extension calls give a busy signal and don't place at all.
There is the possibility that a call that comes into the system but is then forwarded to a CELL PHONE -does- have inbound audio. (What?)
I have attempted DMZing the router and painstakingly re-forwarding the ports to no avail. Even if this is the issue, I don't understand why it would be blocking the extension-to-extension calls. I rebooted the phones, the services, and the server.
I really don't know where else to go on this issue and I don't what's going on with all the Park Orb/Conf messages in the following log, but I suspect they may be related.
Posting here in the in the hopes someone may have an inkling as to what's going on.
Following is a server activity log immediately following an attempted ext-to-ext call, from the time the server was rebooted:
Symptoms:
Code:
19-Jun-2013 12:28:34.786 [CM504002]: Endpoint Conf:7004: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:34.785 [CM504002]: Endpoint Conf:7003: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:34.785 [CM504002]: Endpoint Conf:7002: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:34.784 [CM504002]: Endpoint Conf:7001: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:34.782 [CM504002]: Endpoint Conf:7000: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:34.492 [EC100006]: Connection with Conference server is lost
19-Jun-2013 12:28:32.374 [CM504010]: Fax Service: Fax.8888 unregistered contact sip:8888:5100;user=phone
19-Jun-2013 12:28:30.911 [CM504002]: Endpoint Ivr:RecordFile: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:30.910 [CM504002]: Endpoint Ivr:PlayFile: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:30.910 [CM504002]: Endpoint Ivr:MakeCall: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:30.910 [CM504002]: Endpoint Ivr:IVRForward: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:30.910 [CM504002]: Endpoint Ivr:EndCall: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:30.909 [CM504002]: Endpoint Ivr:8001: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:30.907 [CM504002]: Endpoint Ivr:7777: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:30.904 [CM504002]: Endpoint Ivr:HOL: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:30.902 [CM504002]: Endpoint VMail:9999: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:30.407 [EC100004]: Connection with IVR server is lost
19-Jun-2013 12:28:29.604 [EC100002] Connection with media server is lost
19-Jun-2013 12:28:25.757 [CM504002]: Endpoint ParkOrb:*777: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:25.240 [CM504002]: Endpoint ParkOrb:SP9: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:25.148 [CM504002]: Endpoint ParkOrb:SP8: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:25.147 [CM504002]: Endpoint ParkOrb:SP7: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:25.147 [CM504002]: Endpoint ParkOrb:SP6: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:25.147 [CM504002]: Endpoint ParkOrb:SP5: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:25.146 [CM504002]: Endpoint ParkOrb:SP4: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:25.144 [CM504002]: Endpoint ParkOrb:SP3: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:25.141 [CM504002]: Endpoint ParkOrb:SP2: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:25.140 [CM504002]: Endpoint ParkOrb:SP1: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:25.139 [CM504002]: Endpoint ParkOrb:SP0: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:25.137 [CM504002]: Endpoint ParkOrb:*1: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:25.135 [CM504002]: Endpoint ParkOrb:*0: a contact is unregistered. Contact(s): []
19-Jun-2013 12:28:24.878 [EC100005]: Connection with Parking Orbit server is lost
19-Jun-2013 12:28:23.605 [EC100007]: External application [101Mobility-3CX:0/QueueManager] is disconnected:
19-Jun-2013 12:26:35.374 Leg L:4.2[VMail] is terminated: Cause: BYE from PBX
19-Jun-2013 12:26:35.374 [CM503008]: Call(C:4): Call is terminated
19-Jun-2013 12:26:35.372 Leg L:4.1[Line:10000<<CELL-NUMBER] is terminated: Cause: BYE from IP:5060
19-Jun-2013 12:26:27.970 Currently active calls - 1: [4]
19-Jun-2013 12:25:57.965 Currently active calls - 1: [4]
19-Jun-2013 12:25:25.960 Currently active calls - 1: [4]
19-Jun-2013 12:25:13.624 [CM503007]: Call(C:4): VMail:9999 has joined, contact <sip:[email protected]:40600>
19-Jun-2013 12:25:13.624 [CM503007]: Call(C:4): Line:10000<<CELL-NUMBER has joined, contact <sip:[email protected]:5060>
19-Jun-2013 12:25:13.620 L:4.2[VMail] has joined to L:4.1[Line:10000<<CELL-NUMBER]
19-Jun-2013 12:25:13.620 NAT/ALG check:L:4.2[VMail] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
19-Jun-2013 12:25:13.420 [CM503025]: Call(C:4): Calling T:VMail:9999@[Dev:sip:9999@IP:40600;rinstance=267a511582b1636a] for L:4.1[Line:10000<<CELL-NUMBER]
19-Jun-2013 12:25:13.401 [CM503027]: Call(C:4): From: Line:10000<<CELL-NUMBER ("WIRELESS CALLER" <sip:CELL-NUMBER@3CX-SERVER-IP:5060>) to T:VMail:9999@[Dev:sip:9999@IP:40600;rinstance=267a511582b1636a]
19-Jun-2013 12:25:13.401 [CM503004]: Call(C:4): Route 1: from L:4.1[Line:10000<<CELL-NUMBER] to T:VMail:9999@[Dev:sip:9999@IP:40600;rinstance=267a511582b1636a]
19-Jun-2013 12:25:13.401 [CM505003]: Provider:[Nex] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Asterisk PBX (digium)] PBX contact: [sip:key@IP:5060]
19-Jun-2013 12:25:13.396 [CM503001]: Call(C:4): Incoming call from Line:10000<<CELL-NUMBER to <sip:9999@IP:5060>
19-Jun-2013 12:25:13.396 Line limit check: Current # of calls for line Lc:10000(@Nex[<sip:[email protected]:5060>]) is 1; limit is 4
19-Jun-2013 12:25:13.396 NAT/ALG check:L:4.1[Line:10000<<CELL-NUMBER] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
SIP proxy detected:
Via:SIP/2.0/UDP IP:5060;branch=z9hG4bK854e.b8f89b54.0
Via:SIP/2.0/UDP IP:5060;branch=z9hG4bK-ed510-51c1e977-ef8bb3f-8bcd6d1
Media session IP ('c=' attribute) is not equal to the SIP packet source(IP:port):
Media session IP: IP
Received from: IP
19-Jun-2013 12:25:13.317 [CM503012]: Inbound any hours rule (unnamed) for 10000 forwards to DN:9999
19-Jun-2013 12:24:56.171 Leg L:3.2[VMail] is terminated: Cause: BYE from PBX
19-Jun-2013 12:24:56.170 [CM503008]: Call(C:3): Call is terminated
19-Jun-2013 12:24:56.167 Leg L:3.1[Extn] is terminated: Cause: BYE from IP:5060
19-Jun-2013 12:24:55.958 Currently active calls - 1: [3]
19-Jun-2013 12:24:44.232 [CM503007]: Call(C:3): VMail:9999 has joined, contact <sip:9999@IP:40600>
19-Jun-2013 12:24:44.231 [CM503007]: Call(C:3): Extn:1000 has joined, contact <sip:1000@IP:5060>
19-Jun-2013 12:24:44.229 L:3.2[VMail] has joined to L:3.1[Extn]
19-Jun-2013 12:24:44.229 NAT/ALG check:L:3.2[VMail] RESPONSE 200 on 'INVITE' - basic check passed. No information for extended checks
19-Jun-2013 12:24:44.079 [CM503025]: Call(C:3): Calling T:VMail:9999@[Dev:sip:9999@IP:40600;rinstance=267a511582b1636a] for L:3.1[Extn]
19-Jun-2013 12:24:44.030 [CM503027]: Call(C:3): From: Extn:1000 ("NAME" <sip:[email protected]:5060>) to T:VMail:9999@[Dev:sip:[email protected]:40600;rinstance=267a511582b1636a]
19-Jun-2013 12:24:44.030 [CM503004]: Call(C:3): Route 1: from L:3.1[Extn] to T:VMail:9999@[Dev:sip:9999@IP:40600;rinstance=267a511582b1636a]
19-Jun-2013 12:24:44.029 [CM503001]: Call(C:3): Incoming call from Extn:1000 to <sip:9999@IP:5060>
19-Jun-2013 12:24:44.029 NAT/ALG check:L:3.1[Extn] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
SIP contact header is not equal to the SIP packet source(IP:port):
Contact address:IP:5060
Received from :IP:5060
Received from: IP
19-Jun-2013 12:24:40.838 Leg L:1.1[Line:10000<<xxx] is terminated: Cause: BYE from PBX
19-Jun-2013 12:24:40.838 [CM503008]: Call(C:1): Call is terminated
19-Jun-2013 12:24:40.836 Leg L:1.2[Extn] is terminated: Cause: BYE from IP:5060
19-Jun-2013 12:24:32.633 [MS105000] C:2.1: No RTP packets were received:remoteAddr=127.0.0.1:32000,extAddr=0.0.0.0:0,localAddr=IP:7012
19-Jun-2013 12:24:32.103 Leg L:2.2[Line:10000>>1+###########] is terminated: Cause: 487 Request Terminated/INVITE from IP:5060
19-Jun-2013 12:24:31.964 Leg L:1.5[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 192.168.1.168:5060
19-Jun-2013 12:24:31.963 [CM503003]: Call(C:1): Call to <sip:1001@IP:5060> has failed; Cause: 487 Request Terminated/INVITE from IP:5060
19-Jun-2013 12:24:31.935 Leg L:1.6[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 192.168.1.182:5060
19-Jun-2013 12:24:31.934 [CM503003]: Call(C:1): Call to <sip:1004@IP:5060> has failed; Cause: 487 Request Terminated/INVITE from IP:5060
19-Jun-2013 12:24:31.921 Leg L:1.4[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 192.168.1.191:5060
19-Jun-2013 12:24:31.920 [CM503003]: Call(C:1): Call to <sip:1003@IP:5060> has failed; Cause: 487 Request Terminated/INVITE from IP:5060
19-Jun-2013 12:24:31.920 [CM503008]: Call(C:2): Call is terminated
19-Jun-2013 12:24:31.919 Leg L:2.1[Extn] is terminated: Cause: CANCEL from 127.0.0.1:5488
19-Jun-2013 12:24:31.918 Leg L:1.3[Extn] is terminated: Cause: 487 Request Terminated/INVITE fromIP:5488
19-Jun-2013 12:24:31.917 [CM503003]: Call(C:1): Call to <sip:1000@3CX-SERVER-IP:5060> has failed; Cause: 487 Request Terminated/INVITE from IP:5488
19-Jun-2013 12:24:31.864 Leg L:1.7[Extn] is terminated: Cause: 487 Request Terminated/INVITE from IP:5060
19-Jun-2013 12:24:31.863 [CM503003]: Call(C:1): Call to <sip:[email protected]:5060> has failed; Cause: 487 Request Terminated/INVITE from IP:5060
19-Jun-2013 12:24:31.721 [CM503007]: Call(C:1): Extn:1000 has joined, contact <sip:1000@IP:5060>
19-Jun-2013 12:24:31.720 [CM503007]: Call(C:1): Line:10000<<pz9325CZak has joined, contact <sip:[email protected]:5060>
19-Jun-2013 12:24:31.718 L:1.2[Extn] has joined to L:1.1[Line:10000<<pz9325CZak]
19-Jun-2013 12:24:31.718 NAT/ALG check:L:1.2[Extn] RESPONSE 200 on 'INVITE' - some of SIP/SDP headers contain inconsistent information or modified by intermediate hop
Media session IP:IP
Received from:IP
19-Jun-2013 12:24:29.162 [CM505003]: Provider:[Nex] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Asterisk PBX (digium)] PBX contact: [sip:key@IP:5060]
19-Jun-2013 12:24:26.934 [CM503025]: Call(C:2): Calling T:Line:10000>>CELL-NUMBER@[Dev:sip:[email protected]:5060] for L:2.1[Extn]
19-Jun-2013 12:24:26.812 [CM503027]: Call(C:2): From: Extn:1000 ("ATSnexgen" <sip:key@3CX-SERVER-IP:5060>) to T:Line:10000>>CELL-NUMBER@[Dev:sip:[email protected]:5060]
19-Jun-2013 12:24:26.812 [CM503004]: Call(C:2): Route 1: from L:2.1[Extn] to T:Line:10000>>CELL-NUMBER@[Dev:sip:[email protected]:5060]
19-Jun-2013 12:24:26.812 Line limit check: Current # of calls for line Lc:10000(@Nex[<sip:[email protected]:5060>]) is 1; limit is 4
19-Jun-2013 12:24:26.812 Call(C:2): Call from Extn:1000 to CELL-NUMBER matches outbound rule 'Rule for Nex'
19-Jun-2013 12:24:26.811 [CM503001]: Call(C:2): Incoming call from Extn:1000 to <sip:CELL-NUMBER@3CX-SERVER-IP:5060>
19-Jun-2013 12:24:26.810 NAT/ALG check:L:2.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
19-Jun-2013 12:24:26.809 NAT/ALG check:L:2.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
19-Jun-2013 12:24:26.456 [CM503025]: Call(C:1): Calling
19-Jun-2013 12:24:26.443 .... Ringing Ring Group... (Poster Edits)
19-Jun-2013 12:24:26.319 [CM505003]: Provider:[Nex] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Asterisk PBX (digium)] PBX contact: [sip:key@IP:5060]
19-Jun-2013 12:24:26.312 [CM503001]: Call(C:1): Incoming call from Line:10000<<xxx to <sip:8000@IP:5060>
19-Jun-2013 12:24:26.311 Line limit check: Current # of calls for line Lc:10000(@Nex[<sip:[email protected]:5060>]) is 1; limit is 4
19-Jun-2013 12:24:26.311 NAT/ALG check:L:1.1[Line:10000<<xxx] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
SIP proxy detected:
Via:SIP/2.0/UDP IP:5060;branch=xxx
Via:SIP/2.0/UDP IP:5060;branch=xxx;rport=5060
Received from: IP
19-Jun-2013 12:24:26.009 [CM503012]: Inbound any hours rule (unnamed) for 10000 forwards to DN:8000
19-Jun-2013 12:24:06.011 [CM504001]: Endpoint Extn:1006: new contact is registered. Contact(s): [sip:1006@IP:5060 / 1006]
19-Jun-2013 12:22:34.426 [CM504001]: Endpoint Extn:1002: new contact is registered. Contact(s): [sip:1002@IP:5065 / 1002]
19-Jun-2013 12:22:31.400 [CM504001]: Endpoint Ivr:RecordFile: new contact is registered. Contact(s): [sip:RecordFile@IP:40600 / RecordFile]
19-Jun-2013 12:22:31.400 [CM504001]: Endpoint Ivr:PlayFile: new contact is registered. Contact(s): [sip:PlayFile@IP:40600 / PlayFile]
19-Jun-2013 12:22:31.400 [CM504001]: Endpoint Ivr:MakeCall: new contact is registered. Contact(s): [sip:MakeCall@IP:40600 / MakeCall]
19-Jun-2013 12:22:31.399 [CM504001]: Endpoint Ivr:IVRForward: new contact is registered. Contact(s): [sip:IVRForward@IP:40600 / IVRForward]
19-Jun-2013 12:22:31.399 [CM504001]: Endpoint Ivr:EndCall: new contact is registered. Contact(s): [sip:EndCall@IP:40600 / EndCall]
19-Jun-2013 12:22:31.399 [CM504001]: Endpoint Ivr:8001: new contact is registered. Contact(s): [sip:8001@IP:40600 / 8001]
19-Jun-2013 12:22:31.396 [CM504001]: Endpoint Ivr:7777: new contact is registered. Contact(s): [sip:7777@IP:40600 / 7777]
19-Jun-2013 12:22:31.390 [CM504001]: Endpoint Ivr:HOL: new contact is registered. Contact(s): [sip:HOL@IP:40600 / HOL]
19-Jun-2013 12:22:31.385 [CM504001]: Endpoint VMail:9999: new contact is registered. Contact(s): [sip:9999@IP:40600 / 9999]
19-Jun-2013 12:22:30.379 [CM504001]: Endpoint ParkOrb:SP9: new contact is registered. Contact(s): [sip:SP9@IP:40000 / SP9]
19-Jun-2013 12:22:29.890 [CM504001]: Endpoint ParkOrb:SP8: new contact is registered. Contact(s): [sip:SP8@IP:40000 / SP8]
19-Jun-2013 12:22:29.890 [CM504001]: Endpoint ParkOrb:SP7: new contact is registered. Contact(s): [sip:SP7@IP:40000 / SP7]
19-Jun-2013 12:22:29.890 [CM504001]: Endpoint ParkOrb:SP6: new contact is registered. Contact(s): [sip:SP6@IP:40000 / SP6]
19-Jun-2013 12:22:29.890 [CM504001]: Endpoint ParkOrb:SP5: new contact is registered. Contact(s): [sip:SP5@IP:40000 / SP5]
19-Jun-2013 12:22:29.889 [CM504001]: Endpoint ParkOrb:SP4: new contact is registered. Contact(s): [sip:SP4@IP:40000 / SP4]
19-Jun-2013 12:22:29.887 [CM504001]: Endpoint ParkOrb:SP3: new contact is registered. Contact(s): [sip:SP3@IP:40000 / SP3]
19-Jun-2013 12:22:29.885 [CM504001]: Endpoint ParkOrb:SP2: new contact is registered. Contact(s): [sip:SP2@IP:40000 / SP2]
19-Jun-2013 12:22:29.880 [CM504001]: Endpoint ParkOrb:SP1: new contact is registered. Contact(s): [sip:SP1@IP:40000 / SP1]
19-Jun-2013 12:22:29.876 [CM504001]: Endpoint ParkOrb:SP0: new contact is registered. Contact(s): [sip:SP0@IP:40000 / SP0]
19-Jun-2013 12:22:29.872 [CM504001]: Endpoint ParkOrb:*1: new contact is registered. Contact(s): [sip:*1@IP:40000 / *1]
19-Jun-2013 12:22:29.869 [CM504001]: Endpoint ParkOrb:*0: new contact is registered. Contact(s): [sip:*0@IP:40000 / *0]
19-Jun-2013 12:22:29.866 [CM504001]: Endpoint ParkOrb:*777: new contact is registered. Contact(s): [sip:*777@IP:40000 / *777]
19-Jun-2013 12:22:28.474 [CM504001]: Endpoint Conf:7004: new contact is registered. Contact(s): [sip:7004@IP:40300 / 7004]
19-Jun-2013 12:22:28.474 [CM504001]: Endpoint Conf:7003: new contact is registered. Contact(s): [sip:7003@IP:40300 / 7003]
19-Jun-2013 12:22:28.474 [CM504001]: Endpoint Conf:7002: new contact is registered. Contact(s): [sip:7002@IP:40300 / 7002]
19-Jun-2013 12:22:28.472 [CM504001]: Endpoint Conf:7001: new contact is registered. Contact(s): [sip:7001@IP:40300 / 7001]
19-Jun-2013 12:22:28.467 [CM504001]: Endpoint Conf:7000: new contact is registered. Contact(s): [sip:7000@IP:40300 / 7000]
19-Jun-2013 12:22:26.084 [CM504004]: Registration succeeded for: Lc:10000(@Nex[<sip:[email protected]:5060>])
19-Jun-2013 12:22:25.863 [CM504003]: Sent registration request for Lc:10000(@Nex[<sip:[email protected]:5060>])
19-Jun-2013 12:22:25.763 IP(s) added:[IP]
19-Jun-2013 12:22:23.726 [CM504001]: Endpoint Extn:1000: new contact is registered. Contact(s): [sip:1000@IP:5060 / 1000,sip:[email protected]:5488 / 1000]
19-Jun-2013 12:22:23.723 [CM504001]: Endpoint Ivr:DialCode: new contact is registered. Contact(s): [sip:DialCode@IP:5488 / DialCode]
19-Jun-2013 12:22:22.396 [CM504004]: Registration succeeded for: Lc:10000(@Nex[<sip:[email protected]:5060>])
19-Jun-2013 12:22:21.658 [CM504008]: Fax Service: Fax.8888 registered as sip:[email protected]:5060 with contact sip:8888@IP:5100;user=phone
19-Jun-2013 12:22:21.619 [CM504001]: Endpoint Extn:1001: new contact is registered. Contact(s): [sip:1001@IP:5060 / 1001]
19-Jun-2013 12:22:21.178 [EC200002]: Media server is connected:
application:101Mobility-3CX:0/MediaServer
local:IP:5482
remote:IP:49175
19-Jun-2013 12:22:20.179 [CM504001]: Endpoint Extn:1003: new contact is registered. Contact(s): [sip:1003@PHONE-IP:5060 / 1003]
19-Jun-2013 12:22:18.560 [CM504001]: Endpoint Extn:1007: new contact is registered. Contact(s): [sip:[email protected]:59330 / 1007]
19-Jun-2013 12:22:18.019 [CM504001]: Endpoint Extn:1000: new contact is registered. Contact(s): [sip:1000@PHONE-IP:5060 / 1000]
19-Jun-2013 12:22:17.990 [CM504001]: Endpoint Extn:1004: new contact is registered. Contact(s): [sip:1004@PHONE-IP:5060 / 1004]
19-Jun-2013 12:22:17.651 [CM504003]: Sent registration request for Lc:10000(@Nex[<sip:[email protected]:5060>])
19-Jun-2013 12:22:17.610 [CM506002]: Resolved SIP external IP:port (external IP:5060) on Transport 192.168.1.79:5060
19-Jun-2013 12:22:17.534 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 198.50.247.220:3478 over Transport 192.168.1.79:5060
19-Jun-2013 12:22:15.933 [CM501006]: Default Local IP address: [SERVER-IP]
19-Jun-2013 12:22:15.932 [CM501002]: Version: 11.0.28862.0
19-Jun-2013 12:22:15.932 [CM501001]: Start 3CX PhoneSystem Call Manager
19-Jun-2013 12:22:15.910 [CM501009]: License Info: Loaded Succeeded
19-Jun-2013 12:22:15.703 [CM501007]: *** Started Calls Controller thread ***
