No inbound audio - Only with one provider, others OK
Discussion in '3CX Phone System - General' started by jlag, Feb 15, 2011.
  1. jlag
    Feb 14, 2011
    34
    I have 3 VOIP providers set up.
    VOIPVOIP
    Vonage Soft Phone
    FreePBX
    The trunks from VOIPVOIP and Vonage work perfectly, the FreePBX trunk has no inbound audio.
    Seems strange that the other providers work and this one does not.
    The macnine is on a DMZ ip address.
    Router is forwarding:
    3748 tcp/udp
    5000-5500 tcp/udp
    9000-20000 udp
    21:10:14.937 [MS105000] C:4.1: No RTP packets were received:remoteAddr=67.231.8.106:27574,extAddr=0.0.0.0:0,localAddr=172.16.0.120:7010
    Firewall Checker reports no warnings or errors.
    When I set the FreePBX trunk up on my astrisk server with outside IP address all works fine.
    Any thoughts?
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    you would need to do a wireshark capture to see where the packets are going missing.
  3. jlag
    Feb 14, 2011
    34
    Well I took a look with the port monitor and clearly these frames are not making it past the router. I then forwarded ports 5000 to 60000 to this machine and still don't see any frames from the provider on the lan.
    I do see them with the VOIPVOIP and the Vonage Soft. It makes me think they are never getting out of the providers site.
    Too bad, the latency and quality is very good on the outbound with this trunk. I really don't know what to do next with this. Can I sniff the frames on the wan side of the router? If they are there, what to do? If they aren't there, what to do?
    Tried with 3 routers, ActionTec, D-Link and a Netgear.
  4. leejor
    11,116
    329
    Yes, you can, if you have a separate modem and router, insert a HUB (not a switch) in-between. Connect the PC running Wireshark to one of the other ports. If the PC is set to use DHCP it should pick up a second public IP from your provider, if they allow you to have one.
  5. jlag
    Feb 14, 2011
    34
    I got everything setup for packet sniffing on the wan side. I moved 3cx to a different machine so I could clone the MAC address to eliminate my router from the equation as well. When I connected the test computer to the network, before I even took the router out of the loop, everything started working. The frames that were not on the net before magically appeared. Interesting stuff.
    Thanks for the help. All is at least communicating now.
