No Inbound Audio
Discussion in 'Windows' started by Samwise, Sep 20, 2010.
  1. Samwise
    Sep 20, 2010
    My outbound audio is working fine people can hear me no problem
    There is no inbound audio meaning i cant hear people on the other end.
    I'm extreemly disapointed i love the application love the GUI
    I want it work
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,582
    115
    You could try disabling / configuring your router's firewall and see if that helps.
  3. bluespiderit
    Jun 17, 2010
    9
    Is QOS setup/setup incorrectly on your router?
  4. Samwise
    Sep 20, 2010
    The firewall is totaly disabled /deactivated
  5. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,531
    69
    Hi Sam
    To diagnose missing of incoming audio the first step is to check if you hear "touchtones" or "dialtone" when you dial - these are local sounds and will provide a good hint about how local audio playback device is set. Next, try a call to 999 (voicemail) - it's only you and the PBX. If isn't working, if PBX is located on internet, be sure you set it into "out-of office" fields, to ensure STUN resolution of RTP ports. If PBX is on intranet, be sure you set it into "in-office" field, to ensure STUN resolution is NOT invoked for RTP ports. If you suspect a firewall issue a good idea is to to use the tunnel. If none of them works, another possible issue might be the audio codec - not probable in case of 3CXPhone and 3CX PBX, however, if you have access to the PBX, try to configure on extension's page "PBX delivers audio" - this will force PBX to transcode sound.
    Regards
    vali
  6. Samwise
    Sep 20, 2010
    Thankyou for your help
    Worked it out it was the router blocking
    Fix set the router to bridge mode
