No Inbound Call posible
Discussion in '3CX Phone System - General' started by alex_omega, Mar 10, 2008.
  1. alex_omega
    Mar 10, 2008
    5
    my problem is that i can make calls outside but when calling from outside signaling is OK but not voice.
    I have 3 Patton Gateway one is working fine. (192.168.44.31) in swiss.
    02:10:25.875|.\MSEndPoint.cpp(1300)|Log2||??:[MS210000] C:1.1:Offer received. RTP connection: 192.168.1.230:57456(57457)
    02:10:25.925|.\MSEndPoint.cpp(1062)|Log2||??:[MS210006] C:1.2:Offer provided. Connection(by pass mode): 192.168.1.230:57456(57457)
    02:10:28.038|.\MSEndPoint.cpp(1305)|Log2||??:[MS210001] C:1.2:Answer received. RTP connection: 192.168.2.59:4906(4907)
    02:10:28.038|.\MSEndPoint.cpp(1067)|Log2||??:[MS210007] C:1.1:Answer provided. Connection(by pass mode): 192.168.2.59:4906(4907)
    02:10:41.525|.\MSEndPoint.cpp(1300)|Log2||??:[MS210000] C:2.1:Offer received. RTP connection: 192.168.2.59:4908(4909)
    02:10:41.545|.\MSEndPoint.cpp(1027)|Log2||??:[MS210004] C:2.2:Offer provided. Connection(proxy mode): 192.168.1.87:7006(7007)
    02:10:43.888|.\MSEndPoint.cpp(1305)|Log2||??:[MS210001] C:2.2:Answer received. RTP connection: 192.168.1.230:52006(52007)
    02:10:43.888|.\MSEndPoint.cpp(1032)|Log2||??:[MS210005] C:2.1:Answer provided. Connection(proxy mode):127.0.0.1:7004(7005)
    02:10:47.362|.\MSEndPoint.cpp(517)|Error1||??:[MS105000] C:2.1: No RTP packets were received:remoteAddr=192.168.2.59:4908,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7004
    02:10:53.509|.\MSEndPoint.cpp(1300)|Log2||??:[MS210000] C:3.1:Offer received. RTP connection: 192.168.2.58:4876(4877)
    02:10:53.529|.\MSEndPoint.cpp(1027)|Log2||??:[MS210004] C:3.2:Offer provided. Connection(proxy mode): 192.168.1.87:7010(7011)
    02:10:58.435|.\MSEndPoint.cpp(1305)|Log2||??:[MS210001] C:3.2:Answer received. RTP connection: 192.168.1.230:50962(50963)
    02:10:58.445|.\MSEndPoint.cpp(1032)|Log2||??:[MS210005] C:3.1:Answer provided. Connection(proxy mode):127.0.0.1:7008(7009)
    02:11:04.032|.\MSEndPoint.cpp(517)|Error1||??:[MS105000] C:3.1: No RTP packets were received:remoteAddr=192.168.2.58:4876,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7008
    02:13:19.469|.\MSEndPoint.cpp(1300)|Log2||??:[MS210000] C:4.1:Offer received. RTP connection: 192.168.44.31:5244(5245)
    02:13:19.489|.\MSEndPoint.cpp(1062)|Log2||??:[MS210006] C:4.2:Offer provided. Connection(by pass mode): 192.168.44.31:5244(5245)
    02:13:21.011|.\MSEndPoint.cpp(1305)|Log2||??:[MS210001] C:4.2:Answer received. RTP connection: 192.168.1.230:50732(50733)
    02:13:21.011|.\MSEndPoint.cpp(1067)|Log2||??:[MS210007] C:4.1:Answer provided. Connection(by pass mode): 192.168.1.230:50732(50733)
    I do not understand when calling from outside over the other two gateways 192.168.2.58 and 192.168.2.59 the proxymode is used with 127.0.0.1.
    Could you please help me or tell me what log i have to post for help.
    thanks in advanced
    Alexander
    I was to fast on Submit:
    I'am using 5.1.4128.0, IP Lokal LAN is 192.168.1.87 and IP DMZ 192.168.45.157, Firewalltest is fine.
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    I had the same problem but without the Patton. In my case I had to search for the problem in NAT.
    And the 127.0.0.1 is not normal allthough some say it' s right and no problem.
    In your case I should look for the connection between the Patton and the network / 3CX. Are all the configuration possibil. right in the patton. Is there a port which is blocked by any router or modem? Like port 5060. You have put 3CX in a DMZ, that' s nice to try but I think you should look for the problem in the Patton configur. or blocked ports.
  3. alex_omega
    Mar 10, 2008
    5
    I have still the same problem. Now i reconfigured everything 3CX only on LAN with 192.168.1.87 the Gateway is on 192.168.1.59
    Outbound no problem, inbound no RTP (no Voice). I'am no shure why 3CX is going to use proxy mode and not to by pass mode. Is this a bug?
    Here the outside call (everything fine):
    20:31:23.856|.\MediaServer.cpp(487)|Trace5||??:EndPoint created: (destination=192.168.1.230)
    EndPoint: ID=00000006@(LOCAL)
    Status: MSEP_LOCAL
    RTP:192.168.1.87:7010
    RTCP:192.168.1.87:7011
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    NOT SET
    101:telephony-event
    Party ptime:20
    Party RTP:0.0.0.0:0
    Party RTCP:0.0.0.0:0
    Decoders:
    <empty>
    20:31:23.856|.\MediaServer.cpp(933)|Trace5||??:EP 00000006@ joined to call 4
    20:31:23.856|.\MediaServer.cpp(942)|Trace5||??:starting send on new call 4
    20:31:23.886|.\MediaServer.cpp(584)|Trace5||??:Set Party EP:C:4.1SDP:v=0
    o=root 141037007 141037007 IN IP4 192.168.1.230
    s=call
    c=IN IP4 192.168.1.230
    t=0 0
    m=audio 57442 RTP/AVP 0 8 9 2 3 18 4 101
    a=rtpmap:0 pcmu/8000
    a=rtpmap:8 pcma/8000
    a=rtpmap:9 g722/8000
    a=rtpmap:2 g726-32/8000
    a=rtpmap:3 gsm/8000
    a=rtpmap:18 g729/8000
    a=rtpmap:4 g723/8000
    a=rtpmap:101 telephone-event/8000
    a=fmtp:101 0-16
    a=ptime:20
    a=sendrecv
    20:31:23.886|.\MSEndPoint.cpp(2203)|Trace5||??:New state00000006@ SILENCE
    20:31:23.886|.\MSEndPoint.cpp(1300)|Log2||??:[MS210000] C:4.1:Offer received. RTP connection: 192.168.1.230:57442(57443)
    20:31:23.916|.\MediaServer.cpp(487)|Trace5||??:EndPoint created: (destination=192.168.1.59)
    EndPoint: ID=00000007@(LOCAL)
    Status: MSEP_LOCAL
    RTP:192.168.1.87:7012
    RTCP:192.168.1.87:7013
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    NOT SET
    101:telephony-event
    Party ptime:20
    Party RTP:0.0.0.0:0
    Decoders:
    <empty>
    20:31:23.916|.\MediaServer.cpp(933)|Trace5||??:EP 00000007@ joined to call 4
    20:31:23.916|.\MediaServer.cpp(978)|Trace5||??:EndPoint 00000007@ removed from call 4
    20:31:23.916|.\MSEndPoint.cpp(2203)|Trace5||??:New state00000007@ SILENCE
    20:31:23.916|.\MSEndPoint.cpp(1062)|Log2||??:[MS210006] C:4.2:Offer provided. Connection(by pass mode): 192.168.1.230:57442(57443)
    20:31:23.916|.\MediaServer.cpp(522)|Trace5||??:Get Local SDP. EP:C:4.2SDP:v=0
    o=3cxPS 399918497792 346315292673 IN IP4 192.168.1.87
    s=3cxPS Audio call
    t=0 0
    a=fmtp:101 0-16
    a=ptime:20
    a=rtpmap:3 gsm/8000
    a=sendrecv
    20:31:26.309|.\MediaServer.cpp(584)|Trace5||??:Set Party EP:C:4.2SDP:v=0
    o=MxSIP 0 10 IN IP4 192.168.1.59
    s=SIP Call
    c=IN IP4 192.168.1.59
    t=0 0
    m=audio 4900 RTP/AVP 0 8 101
    a=sendrecv
    20:31:26.309|.\MSEndPoint.cpp(2203)|Trace5||??:New state00000007@ SILENCE
    20:31:26.309|.\MSEndPoint.cpp(1305)|Log2||??:[MS210001] C:4.2:Answer received. RTP connection: 192.168.1.59:4900(4901)
    20:31:26.319|.\MediaServer.cpp(933)|Trace5||??:EP 00000007@ joined to call 4
    20:31:26.319|.\MSEndPoint.cpp(2203)|Trace5||??:New state00000006@ SILENCE
    20:31:26.319|.\MSEndPoint.cpp(1067)|Log2||??:[MS210007] C:4.1:Answer provided. Connection(by pass mode): 192.168.1.59:4900(4901)
    20:31:26.319|.\MediaServer.cpp(522)|Trace5||??:Get Local SDP. EP:C:4.1SDP:v=0
    o=3cxPS 179583320064 204161941505 IN IP4 192.168.1.87
    s=3cxPS Audio call
    t=0 0
    a=sendrecv
    20:31:29.975|.\MediaServer.cpp(978)|Trace5||??:EndPoint 00000006@ removed from call 4
    20:31:30.005|.\MediaServer.cpp(978)|Trace5||??:EndPoint 00000007@ removed from call 4
    20:31:30.025|.\MediaServer.cpp(737)|Trace5||??:references to EndPoint 00000006@ were removed
    20:31:30.025|.\RTPReceiver.cpp(127)|Trace5||??:Endpoint for socket 596 is not found!
    20:31:30.025|.\MSEndPoint.cpp(528)|Trace5||??:EndPoint 00000006@ destroyed
    20:31:30.085|.\MediaServer.cpp(737)|Trace5||??:references to EndPoint 00000007@ were removed
    20:31:30.085|.\RTPReceiver.cpp(127)|Trace5||??:Endpoint for socket 768 is not found!
    20:31:30.085|.\MSEndPoint.cpp(528)|Trace5||??:EndPoint 00000007@ destroyed
    20:31:30.085|.\MediaServer.cpp(1056)|Trace5||??:references to call 4 were removed
    20:31:30.085|.\MSCallConf.cpp(31)|Trace5||??:Call: 4 destroyed
    And here the call inside (no Voice):
    20:28:42.284|.\MediaServer.cpp(487)|Trace5||??:EndPoint created: (destination=192.168.1.87)
    EndPoint: ID=00000003@(LOCAL)
    Status: MSEP_LOCAL
    RTP:127.0.0.1:7004
    RTCP:127.0.0.1:7005
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    NOT SET
    101:telephony-event
    Party ptime:20
    Party RTP:0.0.0.0:0
    Decoders:
    <empty>
    20:28:42.284|.\MediaServer.cpp(933)|Trace5||??:EP 00000003@ joined to call 2
    20:28:42.284|.\MediaServer.cpp(942)|Trace5||??:starting send on new call 2
    20:28:42.334|.\MediaServer.cpp(584)|Trace5||??:Set Party EP:C:2.1SDP:v=0
    o=MxSIP 0 9 IN IP4 192.168.1.59
    s=SIP Call
    t=0 0
    m=audio 4896 RTP/AVP 8 0 101
    a=rtpmap:8 PCMA/8000
    a=rtpmap:0 PCMU/8000
    a=fmtp:101 0-15
    a=sendrecv
    m=image 4898 udptl t38
    a=T38FaxUdpEC:t38UDPRedundancy
    a=sendrecv
    20:28:42.334|.\MSEndPoint.cpp(2203)|Trace5||??:New state00000003@ SILENCE
    20:28:42.334|.\MSEndPoint.cpp(1300)|Log2||??:[MS210000] C:2.1:Offer received. RTP connection: 192.168.1.59:4896(4897)
    20:28:42.344|.\MediaServer.cpp(487)|Trace5||??:EndPoint created: (destination=192.168.1.230)
    EndPoint: ID=00000004@(LOCAL)
    Status: MSEP_LOCAL
    RTP:192.168.1.87:7006
    RTCP:192.168.1.87:7007
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    NOT SET
    101:telephony-event
    Party ptime:20
    Party RTP:0.0.0.0:0
    Decoders:
    <empty>
    20:28:42.344|.\MediaServer.cpp(933)|Trace5||??:EP 00000004@ joined to call 2
    20:28:42.344|.\MediaServer.cpp(978)|Trace5||??:EndPoint 00000004@ removed from call 2
    20:28:42.344|.\MSEndPoint.cpp(2203)|Trace5||??:New state00000004@ SILENCE
    20:28:42.344|.\MSEndPoint.cpp(1027)|Log2||??:[MS210004] C:2.2:Offer provided. Connection(proxy mode): 192.168.1.87:7006(7007)
    20:28:42.344|.\MediaServer.cpp(522)|Trace5||??:Get Local SDP. EP:C:2.2SDP:v=0
    o=3cxPS 502712500224 369836949505 IN IP4 192.168.1.87
    s=3cxPS Audio call
    c=IN IP4 192.168.1.87
    t=0 0
    m=audio 7006 RTP/AVP 8 0 101
    a=fmtp:101 0-15
    a=sendrecv
    a=sendrecv
    20:28:48.973|.\MediaServer.cpp(584)|Trace5||??:Set Party EP:C:2.2SDP:v=0
    o=root 1211399698 1211399699 IN IP4 192.168.1.230
    s=call
    t=0 0
    m=audio 55068 RTP/AVP 8 0 101
    a=fmtp:101 0-16
    a=sendrecv
    20:28:48.973|.\MSEndPoint.cpp(2203)|Trace5||??:New state00000004@ SILENCE
    20:28:48.973|.\MSEndPoint.cpp(2203)|Trace5||??:New state00000004@ PASSTHROUGH
    20:28:48.973|.\MSEndPoint.cpp(1305)|Log2||??:[MS210001] C:2.2:Answer received. RTP connection: 192.168.1.230:55068(55069)
    20:28:48.973|.\MediaServer.cpp(933)|Trace5||??:EP 00000004@ joined to call 2
    20:28:48.973|.\MSEndPoint.cpp(2203)|Trace5||??:New state00000003@ PASSTHROUGH
    20:28:48.973|.\MSEndPoint.cpp(1032)|Log2||??:[MS210005] C:2.1:Answer provided. Connection(proxy mode):127.0.0.1:7004(7005)
    20:28:48.973|.\MediaServer.cpp(522)|Trace5||??:Get Local SDP. EP:C:2.1SDP:v=0
    o=3cxPS 128379256832 529119838209 IN IP4 127.0.0.1
    s=3cxPS Audio call
    c=IN IP4 127.0.0.1
    t=0 0
    m=audio 7004 RTP/AVP 8 0 101
    c=IN IP4 127.0.0.1
    a=fmtp:101 0-16
    a=sendrecv
    20:28:49.063|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:49.083|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:49.103|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:49.123|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:49.133|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:49.153|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:49.173|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:49.193|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:49.214|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:49.234|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:50.085|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:50.095|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:50.115|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:50.135|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:50.155|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:50.175|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:50.195|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:50.215|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:50.235|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:51.096|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:51.116|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:51.136|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:51.156|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:51.176|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:51.196|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:51.216|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:51.236|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:51.256|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:51.276|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:52.088|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:52.108|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:52.128|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:52.158|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:52.178|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:52.198|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:52.218|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:52.238|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:52.258|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:52.278|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:53.099|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:53.119|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:53.139|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:53.159|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:53.179|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:53.199|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:53.219|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:53.239|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:53.259|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:53.269|.\MSEndPoint.cpp(1391)|Trace5||??:[MS505002] C:2.1:Failed to receive incoming packet recvfrom result=-1 WSAError=10054
    20:28:53.750|.\MediaServer.cpp(978)|Trace5||??:EndPoint 00000003@ removed from call 2
    20:28:53.770|.\MediaServer.cpp(978)|Trace5||??:EndPoint 00000004@ removed from call 2
    20:28:53.800|.\MediaServer.cpp(737)|Trace5||??:references to EndPoint 00000003@ were removed
    20:28:53.800|.\MSEndPoint.cpp(517)|Error1||??:[MS105000] C:2.1: No RTP packets were received:remoteAddr=192.168.1.59:4896,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7004
    20:28:53.800|.\RTPReceiver.cpp(127)|Trace5||??:Endpoint for socket 596 is not found!
    20:28:53.800|.\MSEndPoint.cpp(528)|Trace5||??:EndPoint 00000003@ destroyed
    20:28:53.920|.\MediaServer.cpp(737)|Trace5||??:references to EndPoint 00000004@ were removed
    20:28:53.920|.\RTPReceiver.cpp(127)|Trace5||??:Endpoint for socket 768 is not found!
    20:28:53.920|.\MSEndPoint.cpp(528)|Trace5||??:EndPoint 00000004@ destroyed
    20:28:53.920|.\MediaServer.cpp(1056)|Trace5||??:references to call 2 were removed
    20:28:53.920|.\MSCallConf.cpp(31)|Trace5||??:Call: 2 destroyed
    20:30:44.039|.\MediaServer.cpp(487)|Trace5||??:EndPoint created: (destination=192.168.1.230)
    EndPoint: ID=00000005@(LOCAL)
    Status: MSEP_LOCAL
    RTP:192.168.1.87:7008
    RTCP:192.168.1.87:7009
    STUN RTP:0.0.0.0:0
    STUN RTCP:0.0.0.0:0
    Coder:
    NOT SET
    101:telephony-event
    Party ptime:20
    Party RTP:0.0.0.0:0
    Decoders:
    <empty>
    20:30:44.049|.\MediaServer.cpp(933)|Trace5||??:EP 00000005@ joined to call 3
    20:30:44.049|.\MediaServer.cpp(942)|Trace5||??:starting send on new call 3
    20:30:44.079|.\MediaServer.cpp(584)|Trace5||??:Set Party EP:C:3.1SDP:v=0
    o=root 917835856 917835856 IN IP4 192.168.1.230
    s=call
    t=0 0
    m=audio 53620 RTP/AVP 0 8 9 2 3 18 4 101
    a=rtpmap:3 gsm/8000
    a=fmtp:101 0-16
    a=ptime:20
    a=sendrecv
    20:30:44.079|.\MSEndPoint.cpp(2203)|Trace5||??:New state00000005@ SILENCE
    20:30:44.079|.\MSEndPoint.cpp(1300)|Log2||??:[MS210000] C:3.1:Offer received. RTP connection: 192.168.1.230:53620(53621)
    20:30:44.109|.\MediaServer.cpp(978)|Trace5||??:EndPoint 00000005@ removed from call 3
    20:30:44.209|.\MediaServer.cpp(737)|Trace5||??:references to EndPoint 00000005@ were removed
    20:30:44.209|.\RTPReceiver.cpp(127)|Trace5||??:Endpoint for socket 596 is not found!
    20:30:44.209|.\MSEndPoint.cpp(528)|Trace5||??:EndPoint 00000005@ destroyed
    20:30:44.209|.\MediaServer.cpp(1056)|Trace5||??:references to call 3 were removed
    20:30:44.209|.\MSCallConf.cpp(31)|Trace5||??:Call: 3 destroyed
    I think the problem is use of RTP:127.0.0.1 of the MediaServer
    Could you please help me.
    Alex
  4. landfiets
    Jul 17, 2007
    243
    It looks like he cannot find your patton or something.
    Other thing......he is not resolving stun.
    Did you forward port 3478 or did you configure a right stunserver? Try another when it is well configured.
