No Inbound calls after Caller ID Activated
Discussion in '3CX Phone System - General' started by AldoLinares, Nov 27, 2007.
  1. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    Ok today i activated Caller ID from our PSTN Provider and suddenly i can't get any incoming call:
    This is what i get in the log:
    [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '172.16.4.200'; From: '6641200463'; To: '<10001'; Rline: '<10001'; Contact: '6641200463'
    Any Help?
  2. AldoLinares
    Nov 12, 2007
    135
    This worked for me.
