No inbound calls this morning v12
Discussion in '3CX Phone System - General' started by mobilesoundz, Oct 1, 2013.
  1. mobilesoundz
    Oct 24, 2008
    19
    This morning we have no inbound calls no changes have been made, to try and resolve i have loaded SP1 but this has made no difference, it looks like from the logs it detects the call coming in but does nothing with it, i have changed from digital receptionist to an extension and it makes no difference, please see log below and any help would be appreciated
    01-Oct-2013 09:39:54.905 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Invite-UNK Recv Req INVITE from 84.45.107.53:5060 tid=t7v03ttyBNFtj Call-ID=e5a6f869-a517-1231-1b96-0026b95a467f:
    INVITE sip:micky.mouse@sip.*****.co.uk SIP/2.0
    Via: SIP/2.0/UDP 84.45.107.53;rport=5060;branch=z9hG4bKt7v03ttyBNFtj
    Max-Forwards: 68
    Contact: <sip:mod_sofia@84.45.107.53:5060>
    To: <sip:micky.mouse@sip.*****.co.uk>
    From: "078784536**"<sip:078784536**@84.45.107.53>;tag=292HSZ3S2Xv1D
    Call-ID: e5a6f869-a517-1231-1b96-0026b95a467f
    CSeq: 49972335 INVITE
    Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, UPDATE, INFO, REGISTER, REFER, NOTIFY
    Content-Disposition: session
    Content-Type: application/sdp
    Supported: timer, precondition, path, replaces
    User-Agent: TTNC VoIP Network
    Allow-Events: talk, refer
    Content-Length: 291
    Remote-Party-ID: "078784536**" <sip:078784536**@84.45.107.53>;party=calling;screen=yes;privacy=off
    X-FS-Support: update_display
    11,071
    323
    Are you sure that nothing in your settings has changed, either in the trunks settings or your Domain name settings? This is the sort of log I'd expect to see if you didn't have the Domain Name datafilled ........sip.*****co.uk
