Solved No inbound or outbound calls after reboot.
Discussion in '3CX Phone System - General' started by David Glandorf, Oct 12, 2017.
  1. David Glandorf
    Apr 12, 2017
    5
    The only issue I see in the log is the following ParseException.
    The systems is Version: 15.5.0.3849 with a Yealink T42G
    The only reason I rebooted was because of constant backup failure due to "too many conections" for the SQL DB. Calls worked, the backup had stopped. Once I rebooted the backups work again but no more calls.
    10/11/2017 9:37:47 PM - Exception: ParseException ../../rutil/ParseBuffer.hxx:230, Parse failed unexpected eof in context: <NUMBER> ^ @ ../../rutil/ParseBuffer.hxx:230
  2. GiannosC_3CX
    GiannosC_3CX Guest
  3. David Glandorf
    Apr 12, 2017
    5
    I read through that and I don't see that a conclusion was reached. In this case it is a supported provider, Vitelity. Since the issue wasn't exhibited prior to the reboot I would anticipate some sort of data corruption but I have no idea where to look.
  4. David Glandorf
    Apr 12, 2017
    5
    A restore from the last weekly backup corrected the issue.
  5. GiannosC_3CX
    GiannosC_3CX Guest
    Glad to hear the issue is resolved and thanks for update the post :)
