No incoming callerID OAD
Discussion in '3CX Phone System - General' started by bigchris, Sep 13, 2011.
  1. bigchris
    Feb 7, 2011
    6
    I have a 3cx system (version 9) with a beronet BF1E1 card in it.
    When calling from the ISDN to SIP, I am not getting the callerID (OAD) in 3cx or when I look at the active calls in the Beronet config page.
    What I seem to get in 3cx and on my phones is the string configured in beronet under SIP -> CLIR on SIP
    Any one got any ideas why?
    thanks
    10,570
    247
    Are you certain that it is being sent?
    Being ISDN the CID is a digital signal sent when the incoming call set-up is first sent from the provider, it shouldn't be a "timing" issue as it can be with analogue. It is either not being sent, or a configuration error in the ISDN gateway.
  3. bigchris
    Feb 7, 2011
    6
    I will call our provider in the morning and check!
  4. bigchris
    Feb 7, 2011
    6
    Just to tie up the and finish this thread -
    Yes BT had disabled CLIP on our account for some reason!
