NO Incoming calls with a WellGate 3804A. Out fails.
Discussion in '3CX Phone System - General' started by jmareco, May 16, 2007.
  1. jmareco
    Dec 3, 2006
    6
    Firts the gateway didn`t register. Now is OK.
    I can Place call to PSTN but after I dial 0+number, I hear arround 4 rings before the gateway indicates line in use by LED1, and the call is placed.
    Incoming calls not arrive. I connected 4 lines from a Panasonic PBX. 3CX must to ring in ext 200 (registered), but it is not so. "Allow outbound calls on this line " is checked. "Answer incoming calls on this line " is checked.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,873
    171
    First of all, the welltech is not supported. However you can check the server status logs and try to see what is going on.
    If you connect lines from a PBX then i assume you have used an FXS adapter?
