No incoming number MV-370 *** solved ***
Discussion in '3CX Phone System - General' started by surfie, Sep 24, 2008.
  1. surfie
    May 26, 2007
    31
    since the last firmware update of our Portech MV-370 we receive instead of the incoming number the line ID (10006) on the phone display.
    Tried couple of parameters without any success. Here the log:
    23:26:08.201 Call::Terminate [CM503008]: Call(121): Call is terminated
    23:26:08.201 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for DID:400 forwards to DN:100
    23:26:08.201 LineCfg::getInboundTarget [CM503009]: DID rule (400) is applied to call from sip:10006@pneusoft.dyndns.org:5060 to user_ip
    23:26:08.191 LineCfg::getInboundTarget Looking for inbound target: called=user_ip; caller=10006
    23:26:01.572 Extension::printEndpointInfo [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-CP7970G/8.3.0] Transport: [sip:192.168.90.115:5060]
    23:26:01.572 CallCtrl::eek:nAnsweredCall [CM503002]: Call(121): Alerting sip:100@192.168.90.20:5060;transport=udp
    23:26:01.441 MediaServerReporting::SetRemoteParty [MS210002] C:121.2:Offer provided. Connection(transcoding mode): 192.168.90.115:7096(7097)
    23:26:01.431 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(121): Calling: Ext:Ext.100@[Dev:sip:100@192.168.90.20:5060;transport=udp]
    23:26:01.431 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:100@pneusoft.dyndns.org:5060]
    23:26:01.431 MediaServerReporting::SetRemoteParty [MS210000] C:121.1:Offer received. RTP connection: 192.168.90.235:60000(60001)
    23:26:01.421 CallLeg::setRemoteSdp Remote SDP is set for legC:121.1
    23:26:01.421 Line::printEndpointInfo [CM505002]: Gateway:[Potech_370_A1] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [CM5K (706220)] Transport: [sip:192.168.90.115:5060]
    23:26:01.421 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for DID:400 forwards to DN:100
    23:26:01.421 LineCfg::getInboundTarget [CM503009]: DID rule (400) is applied to call from sip:10006@pneusoft.dyndns.org:5060 to user_ip
    23:26:01.421 LineCfg::getInboundTarget Looking for inbound target: called=user_ip; caller=10006
    23:26:01.411 CallCtrl::eek:nIncomingCall [CM503001]: Call(121): Incoming call from 10006@(Ln.10006@Potech_370_A1) to [sip:100@pneusoft.dyndns.org:5060]
    23:26:01.401 LineCfg::getInboundTarget [CM503012]: Inbound out-of-office hours' rule for DID:400 forwards to DN:100
    23:26:01.401 LineCfg::getInboundTarget [CM503009]: DID rule (400) is applied to call from sip:10006@pneusoft.dyndns.org:5060 to user_ip
    23:26:01.391 LineCfg::getInboundTarget Looking for inbound target: called=user_ip; caller=10006
    23:26:01.361 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:user_ip@192.168.90.115 SIP/2.0
    Via: SIP/2.0/UDP 192.168.90.235:5060;rport=5060;branch=z9hG4bK0bf7718b7b
    Max-Forwards: 70
    Contact: [sip:10006@192.168.90.235:5060]
    To: [sip:user_ip@192.168.90.115]
    From: "+436802175805"[sip:10006@192.168.90.115];tag=7015fad3
    Call-ID: 791fe4a91cdd515f060942c749ff19e9@192.168.90.235
    CSeq: 802 INVITE
    Allow: INVITE, CANCEL, ACK, BYE, NOTIFY, REFER, OPTIONS, INFO, MESSAGE
    Proxy-Authorization: Digest username="10006",realm="3CXPhoneSystem",nonce="12866765160:dfe015592528f33e972eb3abb7298f04",response="b63af93e5b968aa49d0503d757ef47f1",uri="sip:user_ip@192.168.90.115",algorithm=MD5
    Supported: replaces
    User-Agent: CM5K (706220)
    Content-Length: 0
  2. Jirka
    Dec 12, 2007
    6
    Re: No incoming number MV-370
    have you tried to look at the set up in Portech in section MOBILE SETTING --> Sip from. I remember changing this parameter and haveing diferent caller ID combinations at the end.
    Jirka.
  3. surfie
    May 26, 2007
    31
    Hello Jirka,
    thanks for reply, worked perfect, the setting had to be in Mobile / Settings: User / User (Standard)
    We tried on the wrong point in the config of the 3CX.
  4. Powermage
    Powermage New Member
    Mar 19, 2008
    103
    Strange, we have recieved an MV-372, i have also the problem that the inbound caller ID is the line number from 3cx,
    i can see the original number in the invite:
    Code:
    INVITE sip:user_ip@192.168.17.40 SIP/2.0
    Via: SIP/2.0/UDP 192.168.17.52:5060;rport=5060;branch=z9hG4bK75ca1251b1
    Max-Forwards: 70
    Contact: [sip:10010@192.168.17.52:5060]
    To: [sip:user_ip@192.168.17.40]
    From: "0612345678"[sip:10010@192.168.17.40];tag=3f80dcdd
    Call-ID: 0ad4a8fe0fa2c140063d58c5258ef0b6@192.168.17.52
    CSeq: 802 INVITE
    Proxy-Authorization: Digest username="10010",realm="3CXPhoneSystem",nonce="12876858051:3eaefa2f5df04d08edccea7c9f4db64b",response="4973e58cd64c8f95581c8485431f500c",uri="sip:user_ip@192.168.17.40",algorithm=MD5
    Supported: replaces
    Content-Length: 0
    l but when i change the SIP From to User/User (standard) i get an invite whithout the number.
    Code:
    Via: SIP/2.0/UDP 192.168.17.52:5060;rport=5060;branch=z9hG4bKb86091b9b3
    Max-Forwards: 70
    From: "GSM-1"[sip:10010@192.168.17.40];tag=57f956a6
    Call-ID: 779d743e023acfcc63205b386144ec5f@192.168.17.52
    CSeq: 802 INVITE
    Proxy-Authorization: Digest username="10010",realm="3CXPhoneSystem",nonce="12876859771:34a633bed5cb02e670b31e3c30a60db5",response="a7c1fc3aa0f164e69b0a1fdc5db26a06",uri="sip:user_ip@192.168.17.40",algorithm=MD5
    Supported: replaces
    Content-Length: 0
