- Joined
- Aug 25, 2011
- Messages
- 6
- Reaction score
- 0
Hi to all!
I'm using the 3CX PBX since 2 years behind a ISP router, and it works perfectly,
Now I added a load balance router behind the ISP router in my office network and opened all the ports needed by 3CX on the router.
The problem is now that I can't hear the incoming voice from the phones!!
This is the log of the firewall checker, as you can see there is a warning on the port translation.
How can I disable the port trasnlation? I can't see no option in the routers!!
I also found this problem in the 3cx log:
Actually the router are set in this way:
DSL router 1 (main DSL line, Static IP)-> all the ports opened to the Load balance router
DSL router 2 (backup DSL line, dynamic IP)-> all the ports opened to the Load balance router
Load balance router -> 3CX server (Win 2K8 enterprise) opened ports: 5060,5061,5090,5000 and the range between 9000 and 9050.
I also set on the load balance router that the whole traffic generated by these ports should pass through DSL router 1, that has a static IP.
How can I resolve this?
Code:
3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
<20:11:20>: Phase 1, checking servers connection, please wait...
<20:11:20>: Stun Checker service is reachable. Phase 1 check passed.
<20:11:20>: Phase 2a, Check Port Forwarding to UDP SIP port, please wait...
<20:11:20>: UDP SIP Port is set to 5060. Response received WITH TRANSLATION 6369::5060. Phase 2a check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<20:11:20>: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
<20:11:20>: TCP SIP Port is set to 5060. Response received WITH TRANSLATION 6369::5060. Phase 2b check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<20:11:20>: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
<20:11:20>: TCP TUNNEL Port is set to 5090. Response received WITH TRANSLATION 6401::5090. Phase 3 check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<20:11:20>: Phase 4. Check Port Forwarding to RTP external port range, please wait...
<20:11:39>: UDP RTP Port 9000. Response received WITH TRANSLATION 6433::9000. Phase 4-01 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<20:11:39>: UDP RTP Port 9001. Response received WITH TRANSLATION 6465::9001. Phase 4-02 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<20:11:39>: UDP RTP Port 9002. Response received WITH TRANSLATION 6497::9002. Phase 4-03 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<20:11:39>: UDP RTP Port 9003. Response received WITH TRANSLATION 6529::9003. Phase 4-04 check passed with WARNINGS. Some functionality may be IMPAIRED. For more information, please visit
19:42:30.846 [MS101005] STUN request failed for ports 9000,9001 on STUN server 'stun3.3cx.com:3478'
