No incomming caller ID on Portech MV-372
Discussion in '3CX Phone System - General' started by Powermage, Jan 22, 2009.
  1. Powermage
    Powermage New Member
    Mar 19, 2008
    103
    We have recieved an MV-372, i have the problem that inbound caller ID is the line number from 3cx, I can see the original number in the invite:
    Code:
    [CM500002]: Info on incoming INVITE:
    INVITE sip:user_ip@192.168.17.40 SIP/2.0
    Via: SIP/2.0/UDP 192.168.17.52:5060;rport=5060;branch=z9hG4bK75ca1251b1
    Max-Forwards: 70
    Contact: [sip:10010@192.168.17.52:5060]
    To: [sip:user_ip@192.168.17.40]
    From: [b]"0612345678"[/b][sip:10010@192.168.17.40];tag=3f80dcdd
    Call-ID: 0ad4a8fe0fa2c140063d58c5258ef0b6@192.168.17.52
    CSeq: 802 INVITE
    Allow: INVITE, CANCEL, ACK, BYE, NOTIFY, REFER, OPTIONS, INFO, MESSAGE
    Proxy-Authorization: Digest username="10010",realm="3CXPhoneSystem",nonce="12876858051:3eaefa2f5df04d08edccea7c9f4db64b",response="4973e58cd64c8f95581c8485431f500c",uri="sip:user_ip@192.168.17.40",algorithm=MD5
    Supported: replaces
    User-Agent: CM5K (706220)
    Content-Length: 0
    In another topic (public part of this forum) someone says you can try to put the "SIP From" to "User/User (standard)" but when i use this option i get an invite whithout the number.
    Code:
    Via: SIP/2.0/UDP 192.168.17.52:5060;rport=5060;branch=z9hG4bKb86091b9b3
    Max-Forwards: 70
    From: "GSM-1"[sip:10010@192.168.17.40];tag=57f956a6
    Call-ID: 779d743e023acfcc63205b386144ec5f@192.168.17.52
    CSeq: 802 INVITE
    Proxy-Authorization: Digest username="10010",realm="3CXPhoneSystem",nonce="12876859771:34a633bed5cb02e670b31e3c30a60db5",response="a7c1fc3aa0f164e69b0a1fdc5db26a06",uri="sip:user_ip@192.168.17.40",algorithm=MD5
    Supported: replaces
    Content-Length: 0
    But if i try some options to match the 'Source Identification' 3cx will reports that he cant find the numer so he wont accept the call, who know's wich option i can use to match the incomming caller ID
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    We are in the process of testing this device in our labs. We shall revert once testing is complete.
  3. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    First, flash new firmware.
    I receive Caller ID w/o problems.
    I use MV-370, 372, 374 and 378. No any problem. Greatest device! :lol:
  4. Powermage
    Mar 19, 2008
    103
    I already have firmware "Mobile VoIP2 v6.694.m" do you have a newer one then?
    are you using V6 or V7 (we are running v6 for the moment, we are going to upgrade probably today)
  5. igor.snezhko
    Jan 7, 2008
    668
    7
    Just download last firmware and flash. No matter what version you have currently.
    It works also in v.6
  6. Powermage
    Mar 19, 2008
    103
    The firmware i use is the latest if i must believe the website.
