No interface after upgrade
Discussion in '3CX Phone System - General' started by Jprice1984, Jul 22, 2016.
  1. Jprice1984
    Jul 22, 2016
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi first, confirm that Management Console service & Nginx service is running.
  3. pjk
    pjk
    Apr 17, 2015
    9
    Same issue and all services are running
  4. kustek
    Feb 3, 2011
    try use actual 127.0.0.1 instead of "localhost"
  5. patricksmalley
    May 13, 2016
    12
    I have the same problem on my server:
    management-console-won--load-45336.html
    Upgrade, everything is happy, all services are running. No interface.
    I had to roll back to get my phone system running again.
  6. patricksmalley
    May 13, 2016
    12
    Ok, got mine working. Here are the things I changed:
    1. In the backup.zip I entered the new v15 key (within the xml config file) and re-packed the zip. Why didn't the configuration tool stop the process and give me a chance to fix the problem instead of uninstall/reinstall.
    2. My certificate key file was encrypted so I converted it to a decrypted key. Not sure why the configuration utility didn't catch this.
    With both of these changes things are working great now. Loving the new interface.
