No Known Route - Exchange 2013
Discussion in '3CX Phone System - General' started by r5a, Feb 13, 2013.
  1. r5a
    r5a
    Feb 13, 2013
    I am testing out 3CX and Exchange 2013 in my lab. I have followed: http://www.3cx.com/blog/docs/exchange-server-2013-config/ to the tee. I have the latest SP4 on 3CX and Exchange 2013 is RTM. I gathered around this is a known issue? Any fix yet?
    Exchange 2013 giving a 302 on initial is normal.
    When I dial 800 I get not implemented and it hangs up.
    Here is the sip stack trace
    Code:
    12-Feb-2013 18:10:14.111   Leg L:4.1[Extn] is terminated: Cause: BYE from PBX
    12-Feb-2013 18:10:14.061   Leg L:4.2[Ivr] is terminated: Cause: 302 Moved Temporarily/INVITE from 192.168.88.20:5060
    12-Feb-2013 18:10:14.060   [CM503003]: Call(C:4): Call to <sip:999@192.168.88.20:5060> has failed; Cause: 302 Moved Temporarily/INVITE from 192.168.88.20:5060
    12-Feb-2013 18:10:14.060   [CM503020]: Call(C:4): Normal call termination. Call originator: Extn:200. Reason: Terminated
    12-Feb-2013 18:10:14.060   L:4.1[Extn] failed to reach Ivr:999, reason Redirected
    12-Feb-2013 18:10:14.060   [CM503014]: Call(C:4): No known route from Extn:200 to target: <sip:999@TOREXCH01.toronto.secure:5062>
    12-Feb-2013 18:10:14.060   [CM503006]: Call(C:4): Diverted to: <sip:999@TOREXCH01.toronto.secure:5062>
    12-Feb-2013 18:10:14.060   Call to T:Ivr:999@[Dev:sip:192.168.88.20:5060;transport=TCP] from L:4.1[Extn] failed, cause: Cause: 302 Moved Temporarily/INVITE from 192.168.88.20:5060
    12-Feb-2013 18:10:05.408   Currently active calls - 1: [4]
    12-Feb-2013 18:09:56.625   [CM503025]: Call(C:4): Calling T:Ivr:999@[Dev:sip:192.168.88.20:5060;transport=TCP] for L:4.1[Extn]
    12-Feb-2013 18:09:56.575   [CM503027]: Call(C:4): From: Extn:200 ("my name" <sip:200@192.168.88.35:5060>)  to  T:Ivr:999@[Dev:sip:192.168.88.20:5060;transport=TCP]
    12-Feb-2013 18:09:56.575   [CM503004]: Call(C:4): Route 1: from L:4.1[Extn] to T:Ivr:999@[Dev:sip:192.168.88.20:5060;transport=TCP]
    12-Feb-2013 18:09:56.574   [CM503001]: Call(C:4): Incoming call from Extn:200 to <sip:999@192.168.88.35:5060>
  2. willneumann
    Mar 21, 2013
    This might help http://blog.c7solutions.com/2012/08/configuring-exchange-server-2013.html
