No known route to target Grandstream GXW4104
Discussion in '3CX Phone System - General' started by KOUSIS, Nov 23, 2010.
  1. KOUSIS
    Nov 17, 2010
    26
    Hello
    I followed all the details in how to configure the Grandstream GXW4104 and i even changed the line tones for Greece but i'm still have problem to dial an external number
    The log is like this
    16:40:41.834 [CM503020]: Normal call termination. Reason: Not found
    16:40:41.834 [CM503016]: Call(10): Attempt to reach <sip:2382024662@192.168.1.2> failed. Reason: Not Found
    16:40:41.833 [CM503014]: Call(10): No known route to target: <sip:2382024662@192.168.1.2>
    16:40:41.832 [CM503010]: Making route(s) to <sip:2382024662@192.168.1.2>
    16:40:41.829 [CM505001]: Ext.203: Device info: Device Identified: [Man: Yealink;Mod: T20;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, no-recvonly] UserAgent: [Yealink SIP-T20P 9.50.0.50] PBX contact: [sip:203@192.168.1.2:5060]
    16:40:41.821 [CM503001]: Call(10): Incoming call from Ext.203 to <sip:2382024662@192.168.1.2>
    16:40:34.843 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.1.2:5060
    16:30:46.267 [CM503016]: Call(9): Attempt to reach <sip:02382024662@192.168.1.2> failed. Reason: Not Found
    16:30:46.265 [CM503010]: Making route(s) to <sip:02382024662@192.168.1.2>
    16:30:46.244 [CM503001]: Call(9): Incoming call from Ext.203 to <sip:02382024662@192.168.1.2>
    16:30:32.198 [CM503016]: Call(8): Attempt to reach <sip:2382024662@192.168.1.2> failed. Reason: Not Found
    16:30:32.195 [CM503010]: Making route(s) to <sip:2382024662@192.168.1.2>
    16:30:32.186 [CM503001]: Call(8): Incoming call from Ext.203 to <sip:2382024662@192.168.1.2>
    16:28:15.842 [CM503016]: Call(7): Attempt to reach <sip:6936158137@192.168.1.2> failed. Reason: Not Found
    Any ideas?
    Thank you
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    The reason is specified by this log entry:
    You need to create outbound rule which will fit the pattern of the dialed numbers.
  3. KOUSIS
    Nov 17, 2010
    26
    Thank you for the reply
    Can you point me to an example on how to create this rule?
  4. leejor
    10,863
    303
