No lights are displayed when transferring
Discussion in '3CX Phone System - General' started by Labman, Jul 11, 2010.
  1. Labman
    Jul 11, 2010
    Using a Snom 320 phone, I have the following issue.
    When an incoming call is answered and transferred to any extension with another Snom phone, the lights on the sidecar does not flash at all. As soon as the extension answers the call, the light comes on.
    If it is not an incoming call, but only an internal call, the light flashes and turns stable perfectly.
    Can anyone help me with this please?
  2. jsadan
    May 3, 2010
    91
    Do you have the free version? If so did you check and see if 3CX supports the light issue you are having?
  3. Labman
    Jul 11, 2010
    no it is a commercial version
  4. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi, please update to the latest firmware of phone.
