No music On Hold
Discussion in '3CX Phone System - General' started by ansu2723, Oct 23, 2009.
  1. ansu2723
    Nov 23, 2008
    29
    I got the latest version of the 3cx SMB edition. Everything works great but one thing.
    When I press Hold on my SNOM 370 phone the one that called dont hear any music. Its only silence until I pick up the call again.
    What could that be? I got the on hold music configured.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Could you please specify what is the device(VoiP provider?) which initiate call to your SNOM 370?
    P.S. SNOM 370 is not the source of problem. why do you specify only this device in your report and forget to specify other one?
  3. ansu2723
    Nov 23, 2008
    29
    The Voip provider is Cellip, but I eaven got the same problem if I take 1 of my SNOM370 phones and calls internaly to the other SNOM370 so it isnt the provider. The strange thing is that when I push the hold button the call gets on hold but the music in the 3cx doesnt play.
  4. galega
    Apr 6, 2009
    27
    We have solved this issue deactivating option "Support RE-INVITE" on extension and trunk properties.
