No Option to Pick Up Calls from Receptionist View
Discussion in 'Windows' started by thawk, Oct 11, 2017.
  1. thawk
    Oct 11, 2017
    Using the Receptionist View in the Windows Client on v15, I am missing the option to pick up a ringing call. According to the documentation "You can pick up, divert or drop a call by right-clicking on the call and selecting the desired option." When a call is ringing in and I right-click my options are divert or drop. I have tried using the deskphone CTI mode (preferable) and using the softphone mode. The result is the same so I suspect some sort of permissions but I've tried changing everything I can find. Anyone out there have experience with actually picking up calls using the Receptionist View in the Windows client?
    Thanks.
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    401
    36
    Hello @thawk,
    The first thing you need to check is if the extension that you are using with the Windows Client, has "Perform operations (divert, transfer, pickup)" option enabled in Extensions>Rights Tab.
    I am assuming that this is already correctly configured, as if it weren't, you wouldn't be able to see the other two options(divert,drop) neither
    The only other reason i can think of, is if you are using the same extension for Windows Client as one of the call participants. In this case, you cannot pick up the call. For example, if you have a deskphone with extension 100 and use windows client in CTI mode with the same extension then you cannot pick up a call that is ringing on deskphone with extension 100.
