Solved No outbound 3 digit on a few trunks
Discussion in '3CX Phone System - General' started by theMightyMacBoy, Jun 19, 2017.
  1. theMightyMacBoy
    Mar 21, 2017
    31
    Hi guys,
    We have currently 60 trunks, all with the same provider. Each trunk uses a different set of credentials for e911 (we have 60 locations). Anyways, on some of the trunks we can't use our 3 digit dial outbound rules. When we dial out on certain trunks, my phones say "Temp Unavailable" Not sure what's going on. Carrier says it not their issue, as 55/60 of our trunks with them are working fine. Our outbound settings on the trunks are the same as well... Thoughts?
    10,750
    285
    Sounds like a pretty complicated set-up. I would check the 3CX Activity Log right after a failed call, then compare this to a working call. Are failed calls easily replicated, or is this an intermittent issue?
  3. theMightyMacBoy
    Mar 21, 2017
    31
    I am going to check Activity Log tonight. It is replicated. Constant issue. Our Logging is set to LOW. Going to increase it after hours and make some test calls.
  4. theMightyMacBoy
    Mar 21, 2017
    31
    Fixed it... Someone (me?) fat fingered a rule. Basically all rules under that rule weren't getting processed.... ugh..
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Glad to hear the issue is resolved and thank you for sharing your solution
