- Joined
- Aug 29, 2009
- Messages
- 6
- Reaction score
- 0
Im having an issue with not being able to send outbound audio. I only have a skype online number for dialing in.
It shows in the firewall log tcp port 5090 has translation. I dont know how to resolve that. I have all the correct ports forwarded in my PIX firewall.
The server log says something about recv only.
Does anyone know how to fix this?
Thanks,
Gary
Firewall Checker Log-----------------------------------
3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
<12:21:04>: Phase 1, checking servers connection, please wait...
<12:21:04>: Stun Checker service is reachable. Phase 1 check passed.
<12:21:04>: Phase 2a, Check Port Forwarding to UDP SIP port, please wait...
<12:21:09>: UDP SIP Port is set to 5060. Response received correctly with no translation. Phase 2a check passed.
<12:21:09>: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
<12:21:14>: TCP SIP Port is set to 5060. Response received correctly with no translation. Phase 2b check passed.
<12:21:14>: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
<12:21:18>: TCP TUNNEL Port is set to 5090. Response received WITH TRANSLATION 10543::5090. Phase 3 check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://www.3cx.com/support/firewall-checker.html
<12:21:18>: Phase 4. Check Port Forwarding to RTP external port range, please wait...
<12:21:23>: UDP RTP Port 9000. Response received correctly with no translation. Phase 4-01 check passed.
<12:21:28>: UDP RTP Port 9001. Response received correctly with no translation. Phase 4-02 check passe
Server Log File--------------------------------------
12:13:00.197 [CM503008]: Call(1): Call is terminated
12:13:00.187 [CM503008]: Call(1): Call is terminated
12:12:25.007 [CM503007]: Call(1): Device joined: sip:[email protected]:3446;rinstance=c0d9b5962e11a062
12:12:24.977 [CM503007]: Call(1): Device joined: sip:[email protected]:6060
12:12:23.695 [CM505001]: Ext.11: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.8571.0] Transport: [sip:192.168.1.8:5060]
12:12:23.695 [CM503002]: Call(1): Alerting sip:[email protected]:3446;rinstance=c0d9b5962e11a062
12:12:23.415 [CM503024]: Call(1): Calling RingAll80:11Ext.1113Ext.13@[Dev:sip:[email protected]:3446;rinstance=c0d9b5962e11a062]
12:12:23.394 [CM503004]: Call(1): Route 1: RingAll80:11Ext.1113Ext.13@[Dev:sip:[email protected]:3446;rinstance=c0d9b5962e11a062]
12:12:23.374 [CM503010]: Making route(s) to <sip:[email protected]:5060>
12:12:23.364 [CM505002]: Gateway:[Skypegw] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] Transport: [sip:127.0.0.1:5060]
12:12:23.324 [CM503001]: Call(1): Incoming call from +16318316983@(Ln.10000@Skypegw) to <sip:[email protected]:5060>
12:12:23.294 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:80
12:09:46.058 [CM504001]: Ext.11: new contact is registered. Contact(s): [sip:[email protected]:3446;rinstance=c0d9b5962e11a062/11]
12:08:26.484 [CM504001]: Ext.99: new contact is registered. Contact(s): [sip:[email protected]:40600;rinstance=5735744cbf040f0c/99]
12:08:20.816 IP(s) added:[192.168.1.8]
12:08:13.245 [CM112000] Media Server is connected
12:08:12.364 [CM506002]: Resolved SIP external IPort (68.194.30.175:5060) on Transport 192.168.1.8:5060
12:08:12.153 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.8:5060
12:08:10.951 [CM501006]: Default Local IP address: [192.168.1.8]
12:08:10.921 [CM501007]: *** Started Calls Controller thread ***
12:08:10.751 [CM501002]: Version: 7.1.7060.0
12:08:10.751 [CM501001]: Start 3CX PhoneSystem Call Manager
12:08:10.270 Unknown system [DBProvider] tries to connect!
12:08:10.250 [CM501010]: License Info: Load Failed
Thanks,
Gary
