No Outbound Calls from 3CX Softphone to Skype Gateway
Discussion in '3CX Phone System - General' started by merlinman, Sep 29, 2009.
  1. merlinman
    Sep 29, 2009
    Recently considered transfering our old PBX to 3CX PBX.
    Installed the Skype Gateway showing all ok connected from the gateway to the PBX when making calls from the VOIP client the error log shows the following:
    21:18:29.687 [CM504008]: Fax Service: registered as sip:88@10.1.1.4:5060 with contact sip:88@10.1.1.4:5100;user=phone
    21:13:29.366 [CM504008]: Fax Service: registered as sip:88@10.1.1.4:5060 with contact sip:88@10.1.1.4:5100;user=phone
    21:08:29.094 [CM504008]: Fax Service: registered as sip:88@10.1.1.4:5060 with contact sip:88@10.1.1.4:5100;user=phone
    21:08:20.682 [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 69.0.208.27:3478 over Transport 10.1.1.4:5060
    21:03:28.772 [CM504008]: Fax Service: registered as sip:88@10.1.1.4:5060 with contact sip:88@10.1.1.4:5100;user=phone
    20:58:28.450 [CM504008]: Fax Service: registered as sip:88@10.1.1.4:5060 with contact sip:88@10.1.1.4:5100;user=phone
    20:53:28.108 [CM504008]: Fax Service: registered as sip:88@10.1.1.4:5060 with contact sip:88@10.1.1.4:5100;user=phone
    20:53:12.125 [CM503008]: Call(16): Call is terminated
    20:53:12.085 [CM503015]: Call(16): Attempt to reach <sip:123@10.1.1.4:5060> failed. Reason: Not Found
    20:53:12.085 [CM503014]: Call(16): No known route to target: <sip:123@10.1.1.4:5060>
    20:53:12.025 [CM503010]: Making route(s) to <sip:123@10.1.1.4:5060>
    20:53:12.015 [CM505001]: Ext.15: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.8571.0] Transport: [sip:10.1.1.4:5060]
    20:53:11.945 [CM503001]: Call(16): Incoming call from Ext.15 to <sip:123@10.1.1.4:5060>
    20:52:54.119 [CM503008]: Call(15): Call is terminated
    20:52:54.029 [CM503015]: Call(15): Attempt to reach <sip:093860942@10.1.1.4:5060> failed. Reason: Temporarily Unavailable
    20:52:54.029 [CM503003]: Call(15): Call to sip:93860942@127.0.0.1:6064 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6064
    20:52:54.029 [CM505002]: Gateway:[trunk3] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] Transport: [sip:10.1.1.4:5060]
    20:52:54.029 [CM503002]: Call(15): Alerting sip:10002@127.0.0.1:6064
    20:52:53.769 [CM503024]: Call(15): Calling PSTNline:93860942@(Ln.10002@trunk3)@[Dev:sip:10002@127.0.0.1:6064]
    20:52:53.719 [CM503003]: Call(15): Call to sip:93860942@127.0.0.1:6062 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6062
    20:52:53.709 [CM505002]: Gateway:[trunk2] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] Transport: [sip:10.1.1.4:5060]
    20:52:53.709 [CM503002]: Call(15): Alerting sip:10001@127.0.0.1:6062
    20:52:53.478 [CM503004]: Call(15): Route 2: PSTNline:93860942@(Ln.10002@trunk3)@[Dev:sip:10002@127.0.0.1:6064]
    20:52:53.478 [CM503024]: Call(15): Calling PSTNline:93860942@(Ln.10001@trunk2)@[Dev:sip:10001@127.0.0.1:6062]
    20:52:53.408 [CM503004]: Call(15): Route 1: PSTNline:93860942@(Ln.10001@trunk2)@[Dev:sip:10001@127.0.0.1:6062]
    20:52:53.358 [CM503010]: Making route(s) to <sip:093860942@10.1.1.4:5060>
    20:52:53.348 [CM505001]: Ext.15: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.8571.0] Transport: [sip:10.1.1.4:5060]
    20:52:53.268 [CM503001]: Call(15): Incoming call from Ext.15 to <sip:093860942@10.1.1.4:5060>
    20:52:43.865 [CM503008]: Call(14): Call is terminated
    20:52:43.764 [CM503015]: Call(14): Attempt to reach <sip:093860942@10.1.1.4:5060> failed. Reason: Temporarily Unavailable
    20:52:43.764 [CM503003]: Call(14): Call to sip:93860942@127.0.0.1:6064 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6064
    20:52:43.754 [CM505002]: Gateway:[trunk3] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] Transport: [sip:10.1.1.4:5060]
    20:52:43.754 [CM503002]: Call(14): Alerting sip:10002@127.0.0.1:6064
    20:52:43.504 [CM503024]: Call(14): Calling PSTNline:93860942@(Ln.10002@trunk3)@[Dev:sip:10002@127.0.0.1:6064]
    20:52:43.464 [CM503003]: Call(14): Call to sip:93860942@127.0.0.1:6062 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6062
    20:52:43.454 [CM505002]: Gateway:[trunk2] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] Transport: [sip:10.1.1.4:5060]
    20:52:43.454 [CM503002]: Call(14): Alerting sip:10001@127.0.0.1:6062
    20:52:43.234 [CM503004]: Call(14): Route 2: PSTNline:93860942@(Ln.10002@trunk3)@[Dev:sip:10002@127.0.0.1:6064]
    20:52:43.234 [CM503024]: Call(14): Calling PSTNline:93860942@(Ln.10001@trunk2)@[Dev:sip:10001@127.0.0.1:6062]
    20:52:43.194 [CM503004]: Call(14): Route 1: PSTNline:93860942@(Ln.10001@trunk2)@[Dev:sip:10001@127.0.0.1:6062]
    20:52:43.103 [CM503010]: Making route(s) to <sip:093860942@10.1.1.4:5060>
    20:52:43.093 [CM505001]: Ext.15: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.8571.0] Transport: [sip:10.1.1.4:5060]
    20:52:43.013 [CM503001]: Call(14): Incoming call from Ext.15 to <sip:093860942@10.1.1.4:5060>
    20:52:20.501 [CM504001]: Ext.15: new contact is registered. Contact(s): [sip:15@10.1.1.6:2500;rinstance=8a072434a17a0965/15]
    20:52:16.115 [CM504002]: Ext.15: a contact is unregistered. Contact(s): []
    20:52:15.594 [CM504002]: Ext.15: a contact is unregistered. Contact(s): []
    20:51:14.586 [CM503008]: Call(13): Call is terminated
    20:51:14.546 [CM503015]: Call(13): Attempt to reach <sip:1234@10.1.1.4:5060> failed. Reason: Not Found
    20:51:14.546 [CM503014]: Call(13): No known route to target: <sip:1234@10.1.1.4:5060>
    20:51:14.496 [CM503010]: Making route(s) to <sip:1234@10.1.1.4:5060>
    20:51:14.486 [CM505001]: Ext.15: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.8571.0] Transport: [sip:10.1.1.4:5060]
    20:51:14.406 [CM503001]: Call(13): Incoming call from Ext.15 to <sip:1234@10.1.1.4:5060>
    20:51:11.822 [CM503008]: Call(12): Call is terminated
    20:51:11.782 [CM503015]: Call(12): Attempt to reach <sip:123@10.1.1.4:5060> failed. Reason: Not Found
    20:51:11.782 [CM503014]: Call(12): No known route to target: <sip:123@10.1.1.4:5060>
    20:51:11.732 [CM503010]: Making route(s) to <sip:123@10.1.1.4:5060>
    20:51:11.722 [CM505001]: Ext.15: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.8571.0] Transport: [sip:10.1.1.4:5060]
    20:51:11.632 [CM503001]: Call(12): Incoming call from Ext.15 to <sip:123@10.1.1.4:5060>
    20:51:08.768 [CM503008]: Call(11): Call is terminated
    20:51:08.728 [CM503015]: Call(11): Attempt to reach <sip:echo@10.1.1.4:5060> failed. Reason: Not Found
    20:51:08.728 [CM503014]: Call(11): No known route to target: <sip:echo@10.1.1.4:5060>
    20:51:08.678 [CM503010]: Making route(s) to <sip:echo@10.1.1.4:5060>
    20:51:08.648 [CM505001]: Ext.15: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.8571.0] Transport: [sip:10.1.1.4:5060]
    20:51:08.578 [CM503001]: Call(11): Incoming call from Ext.15 to <sip:echo@10.1.1.4:5060>
    20:51:00.125 [CM503008]: Call(10): Call is terminated
    20:51:00.085 [CM503015]: Call(10): Attempt to reach <sip:merlinman@10.1.1.4:5060> failed. Reason: Not Found
    20:51:00.085 [CM503014]: Call(10): No known route to target: <sip:merlinman@10.1.1.4:5060>
    20:51:00.015 [CM503010]: Making route(s) to <sip:merlinman@10.1.1.4:5060>
    20:51:00.005 [CM505001]: Ext.15: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.8571.0] Transport: [sip:10.1.1.4:5060]
    20:50:59.895 [CM503001]: Call(10): Incoming call from Ext.15 to <sip:merlinman@10.1.1.4:5060>
    20:49:06.973 [CM503008]: Call(9): Call is terminated
    20:49:06.883 [CM503015]: Call(9): Attempt to reach <sip:061393860942@10.1.1.4:5060> failed. Reason: Temporarily Unavailable
    20:49:06.883 [CM503003]: Call(9): Call to sip:61393860942@127.0.0.1:6064 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6064
    20:49:06.873 [CM505002]: Gateway:[trunk3] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] Transport: [sip:10.1.1.4:5060]
    20:49:06.873 [CM503002]: Call(9): Alerting sip:10002@127.0.0.1:6064
    20:49:06.612 [CM503024]: Call(9): Calling PSTNline:61393860942@(Ln.10002@trunk3)@[Dev:sip:10002@127.0.0.1:6064]
    20:49:06.572 [CM503003]: Call(9): Call to sip:61393860942@127.0.0.1:6062 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6062
    20:49:06.562 [CM505002]: Gateway:[trunk2] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] Transport: [sip:10.1.1.4:5060]
    20:49:06.562 [CM503002]: Call(9): Alerting sip:10001@127.0.0.1:6062
    20:49:06.302 [CM503004]: Call(9): Route 2: PSTNline:61393860942@(Ln.10002@trunk3)@[Dev:sip:10002@127.0.0.1:6064]
    20:49:06.302 [CM503024]: Call(9): Calling PSTNline:61393860942@(Ln.10001@trunk2)@[Dev:sip:10001@127.0.0.1:6062]
    20:49:06.252 [CM503004]: Call(9): Route 1: PSTNline:61393860942@(Ln.10001@trunk2)@[Dev:sip:10001@127.0.0.1:6062]
    20:49:06.202 [CM503010]: Making route(s) to <sip:061393860942@10.1.1.4:5060>
    20:49:06.192 [CM505001]: Ext.15: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.8571.0] Transport: [sip:10.1.1.4:5060]
    20:49:06.111 [CM503001]: Call(9): Incoming call from Ext.15 to <sip:061393860942@10.1.1.4:5060>
    20:48:39.403 [CM503008]: Call(8): Call is terminated
    20:48:39.313 [CM503015]: Call(8): Attempt to reach <sip:061393860942@10.1.1.4:5060> failed. Reason: Temporarily Unavailable
    20:48:39.313 [CM503003]: Call(8): Call to sip:61393860942@127.0.0.1:6064 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6064
    20:48:39.303 [CM505002]: Gateway:[trunk3] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] Transport: [sip:10.1.1.4:5060]
    20:48:39.303 [CM503002]: Call(8): Alerting sip:10002@127.0.0.1:6064
    20:48:39.053 [CM503024]: Call(8): Calling PSTNline:61393860942@(Ln.10002@trunk3)@[Dev:sip:10002@127.0.0.1:6064]
    20:48:39.012 [CM503003]: Call(8): Call to sip:61393860942@127.0.0.1:6062 has failed; Cause: 480 Temporarily Unavailable; from IP:127.0.0.1:6062
    20:48:38.992 [CM505002]: Gateway:[trunk2] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.8742.0] Transport: [sip:10.1.1.4:5060]
    20:48:38.992 [CM503002]: Call(8): Alerting sip:10001@127.0.0.1:6062
    20:48:38.742 [CM503004]: Call(8): Route 2: PSTNline:61393860942@(Ln.10002@trunk3)@[Dev:sip:10002@127.0.0.1:6064]
    20:48:38.742 [CM503024]: Call(8): Calling PSTNline:61393860942@(Ln.10001@trunk2)@[Dev:sip:10001@127.0.0.1:6062]
    20:48:38.702 [CM503004]: Call(8): Route 1: PSTNline:61393860942@(Ln.10001@trunk2)@[Dev:sip:10001@127.0.0.1:6062]
    20:48:38.632 [CM503010]: Making route(s) to <sip:061393860942@10.1.1.4:5060>
    20:48:38.622 [CM505001]: Ext.15: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.1.8571.0] Transport: [sip:10.1.1.4:5060]
    Thank You ASAP. Since this is preventing calls for the past two days.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,476
    67
    61393860942 is missing the country code, Skype require this (such as 0035761393860942).
    Also, you MUST have Skype credit, also required by Skype.
    Regards
    vali
  3. merlinman
    Sep 29, 2009
    Thank you for the reply outbound calls seem to be functioning. There is a secondary issue with incoming call not being answered by the skype gateway.
    this includes skype picking up the call but gateway showing the call but the PBX not answering. Digital Auto Attendent answering in configurted with prompts menus stilll not answering call.
    Assistance on where to go from here. I am sure its to do with configuration somewhere.
  4. ayachem
    Oct 1, 2009
    19
    I had a similar issue that had me stumped for quite a while: Outgoing Skype calls were always marked busy and Incoming calls getting answered and immediately dropped.
    Turns out that it was because I had used remote desktop to access my 3CX/Skype Gateway server. When connected via remote desktop, the server thought it had no Microphone available, which causes errors in Skype.
    When disconnected from Remote Desktop, everything worked fine. I recommend using VNC or some alternate method of remoting to the server if necessary.
    ~ Michelle
  5. Vali_3CX
    Dec 12, 2008
    1,476
    67
    Hi, Michelle
    It's true, and the remote desktop connection issue we discussed here a little, please read also this message, it might be useful:
    http://www.3cx.com/forums/skype-gateway-fails-reason-failed-remote-device-error-11531.html#p59303
    Regards
    vali
