No outbound calls
Discussion in '3CX Phone System - General' started by gschwab, Jun 30, 2016.
  1. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    Running 3CX V14 with SP3. system has been working fine until yesterday AM, outbound calls fail with "internal server error"
    I found no obvious issues on my end and firewall checker still passes all tests. Contacted my SIP trunk provider and they say they see the invite from my system but they receive no response to the challenge sent from their system, they think that Frontier (we were with Verizon Fios, now Frontier) my be blocking port 5060. I have tried changing the port but no matter what port I try it will not pass firewall checker Test2. Does 3CX not allow us to change the port?
    Inbound calls working fine.
    Thanks for any suggestions.
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,338
    76
    You can change the SIP Port from Settings -> Network, but as you have changed ISPs I assume the Public IP has changed. Do you have the new static Public IP set in Settings -> Network -> Public IP tab?
    If not change it there and restart all services for the change to take effect.
    Also check in the Provider settings in the "Advanced" tab in case you have overridden the default public IP there and also make the necessary changes if needed.
  3. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    Thanks for the reply, yes public IP is set correctly and my inbound calls work, my big issue is that I can't get 3CX to pass the firewall checker Test 2, one to one forwarding. I change the port forwarding in my router from 5060 to say 5070, I change the port in 3CX Settings -> Network, reboot the router, restart all services and it fails 5070 Test 2 every time, I'm clueless.
  4. NickD_3CX
    Jun 2, 2014
    1,338
    76
    What exactly is the message in the Firewall Checker for 5070?
  5. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    I get
    Test1 reachability test ... resolved public IP: XX.XXX.XXX.27 (i masked this, it DOES show my actual public IP address)
    Test2 one on one port forwarding FAILED...
    no response received or port mapping is closed. firewall check failed, this configuration is not supported.
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,311
    249
    Windows firewall didn't accidentally get turned on?
    try a reboot?
    my system wasn't passing multicast audio for paging. a reboot fixed it.
    every once in a while I see some strange behavior.
  7. NickD_3CX
    Jun 2, 2014
    1,338
    76
    To understand what Test 1 and Test 2 are, as well as the reasons they may fail, there is a very detailed (and slightly technical) article about it here:
    http://www.3cx.com/blog/docs/firewall-voip-rules-check/
    Hopefully this will help understand and troubleshoot the issue you are having.
