No outgoing Calls
Discussion in 'Windows' started by jmatson, Nov 10, 2011.
  1. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    hey Guys just started today. I can not get any outgoing calls.
    Code:
    16:48:46.484  [CM502001]: Source info: From: "Jess"<sip:100@XX>;tag=f7fa57233cf78737o0<sip:5138602573@XX>
    16:48:46.484  [CM503013]: Call(1): Incoming call rejected, caller is unknown; msg=SipReq:  INVITE 5138602573@XX tid=-8d092dab cseq=INVITE contact=100@10.1.10.33:5060 / 102 from(wire)
    16:48:46.484  [CM500002]: Info on incoming INVITE:
      INVITE sip:5138602573@XX SIP/2.0
      Via: SIP/2.0/UDP 10.1.10.33:5060;branch=z9hG4bK-8d092dab
      Max-Forwards: 70
      Contact: "Jess"<sip:100@10.1.10.33:5060>
      To: <sip:5138602573@XX>
      Call-ID: 2d3c1693-c21b4e87@10.1.10.33
      CSeq: 102 INVITE
      Expires: 240
      Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
      Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",nonce="414d535c04cce5ce98:73c0995adea47894d40ee7bfb2764047",uri="sip:5138602573@XX",algorithm=MD5,response="124486e089b3db3a52f6f1d4411c3ff6"
      Supported: replaces
      User-Agent: Linksys/SPA942-6.1.5(a)
      Content-Length: 0
    This is pulled from the logs. The only that happened today i changed the IP of my 3cx box. but i went in and changed everything else in the sytem to deal with the IP
  2. jmatson
    jmatson New Member
    Nov 30, 2009
    122
    i figured it out.
    It didn't like me putting my sip domain in the phone settings. when i changed it back to IP it worked
  3. leejor
    10,367
    228
    Put your SIP domain in the Domain Name setting in 3CX. 3CX should then allow outside extensions to use a URL rather than an IP when contacting 3CX.
