No outgoing calls
Discussion in '3CX Phone System - General' started by gergely, Oct 22, 2012.
  1. gergely
    Oct 22, 2012
    9
    Hi! I'm new to the 3CX Phone system. I read everything then configured the v10 version. I'm using 3cx Phone v6 as softphone.
    Incoming calls are ok, but i can not make outgouning calls. Couldn't try internal calls yet, because 1 only have 1 pc.
    Windows 7 with firewall turned off
    Dlink di-524 router (2 picture attached)
    Firewall checker: OK
    I configure outbound rules.
    Using STUN.
    Network settings is default, only changed the 9000-9049 ports to 9000-9003 (old routers limitation, cant add more rule...)
    Thanks for any help!
    Here is the event log:
    22:52:33.972 [CM503020]: Normal call termination. Reason: Server Failure
    22:52:33.971 [CM503016]: Call(9): Attempt to reach <sip:DIALED-NUMBER@192.168.0.100:5060> failed. Reason: Server Failure
    22:52:33.967 [CM503003]: Call(9): Call to sip:DIALED-NUMBER@MY-VOIP-PROVIDER:5060 has failed; Cause: 500 Gateway Is Invalid; from IP:84.21.11.253:5060
    22:52:31.732 [CM503025]: Call(9): Calling VoIPline:DIALED-NUMBER@(Ln.10000@Generic VoIP Provider -)@[Dev:sip:OWN-NUMBER@MY-VOIP-PROVIDER:5060]
    22:52:31.721 [MS210002] C:9.4:Offer provided. Connection(transcoding mode): 193.91.78.148:9000(9001)
    22:52:31.557 [CM503003]: Call(9): Call to sip:DIALED-NUMBER@MY-VOIP-PROVIDER:5060 has failed; Cause: 500 Gateway Is Invalid; from IP:84.21.11.253:5060
    22:52:29.317 [CM503025]: Call(9): Calling VoIPline:DIALED-NUMBER@(Ln.10000@Generic VoIP Provider -)@[Dev:sip:OWN-NUMBER@MY-VOIP-PROVIDER:5060]
    22:52:29.306 [MS210002] C:9.3:Offer provided. Connection(transcoding mode): 193.91.78.148:9002(9003)
    22:52:29.132 [CM503003]: Call(9): Call to sip:DIALED-NUMBER@MY-VOIP-PROVIDER:5060 has failed; Cause: 500 Gateway Is Invalid; from IP:84.21.11.253:5060
    22:52:28.991 [CM503025]: Call(9): Calling VoIPline:DIALED-NUMBER@(Ln.10000@Generic VoIP Provider -)@[Dev:sip:OWN-NUMBER@MY-VOIP-PROVIDER:5060]
    22:52:28.986 [MS210002] C:9.2:Offer provided. Connection(transcoding mode): 193.91.78.148:9000(9001)
    22:52:28.799 [CM503004]: Call(9): Route 3: VoIPline:DIALED-NUMBER@(Ln.10000@Generic VoIP Provider -)@[Dev:sip:OWN-NUMBER@MY-VOIP-PROVIDER:5060]
    22:52:28.799 [CM503004]: Call(9): Route 2: VoIPline:DIALED-NUMBER@(Ln.10000@Generic VoIP Provider -)@[Dev:sip:OWN-NUMBER@MY-VOIP-PROVIDER:5060]
    22:52:28.798 [CM503004]: Call(9): Route 1: VoIPline:DIALED-NUMBER@(Ln.10000@Generic VoIP Provider -)@[Dev:sip:OWN-NUMBER@MY-VOIP-PROVIDER:5060]
    22:52:28.797 [CM503010]: Making route(s) to <sip:DIALED-NUMBER@192.168.0.100:5060>
    22:52:28.797 [MS210000] C:9.1:Offer received. RTP connection: 192.168.0.100:40046(40047)
    22:52:28.795 Remote SDP is set for legC:9.1
    22:52:28.794 [CM505001]: Ext.100: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 6.0.26523.0] PBX contact: [sip:100@192.168.0.100:5060]
    22:52:28.791 [CM503001]: Call(9): Incoming call from Ext.100 to <sip:DIALED-NUMBER@192.168.0.100:5060>
    22:52:28.782 [CM500002]: Info on incoming INVITE:
    INVITE sip:DIALED-NUMBER@192.168.0.100:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.100:57916;branch=z9hG4bK-d8754z-242b976684709042-1---d8754z-;rport=57916
    Max-Forwards: 70
    Contact: <sip:100@192.168.0.100:57916;rinstance=77b83bb94afed7ce>
    To: <sip:DIALED-NUMBER@192.168.0.100:5060>
    From: "62200150"<sip:100@192.168.0.100:5060>;tag=c610166d
    Call-ID: YjlkYzNhYzhhYzY5N2VjM2JkZWYwNDY0YjIyMzBhMWI.
    CSeq: 2 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
    Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",nonce="414d535c0696430c00:c93d6c4840ec5e8516441f163bce0d9a",uri="sip:DIALED-NUMBER@192.168.0.100:5060",response="aa9d94eea77a40879ba9393ec138b449",algorithm=MD5
    Supported: replaces
    User-Agent: 3CXPhone 6.0.26523.0
    Content-Length: 0
    22:52:25.429 Currently active calls [none]
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,978
    183
    Is the PBX Registering properly, on the Port/Trunk Status page, to your "Generic VoIP Provider" ?
  3. gergely
    Oct 22, 2012
    9
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    You need to resolve the above error. It also appears that you have the same rule invoked three times for the same route. You should first check with your provider and ensure that the settings are correct and then change the outbound rule accordingly such that it only has the one route.
  5. leejor
    10,374
    231
    If this..84.21.11.253, is the IP of your VoIP provider, they may be trying to tell you that you are sending the call attempt to the wrong destination (URL), or something else is incorrect. You may want to review your trunk settings for that provider in 3CX.
  6. gergely
    Oct 22, 2012
    9
    I configured 1 outbound rule, but added the same route 3 times. It's kinda unnecessary. 8|
    I will contact the provider.
  7. gergely
    Oct 22, 2012
    9
    I asked the provider, they couldn't tell anything usefull.
  8. lneblett
    Sep 7, 2010
    2,061
    56
    Nice of them, assuming that the 84.21.11.253 IP is theirs.
  9. leejor
    10,374
    231
    Have you had any service working previously, using this provider?
    Have you tried using the 3CX phone (Windows version?) to register directly with them and place calls. See if that works with the same settings.
  10. gergely
    Oct 22, 2012
    9
    Yes, it's their ip.
  11. gergely
    Oct 22, 2012
    9
    Yes. I used it with NCH Expresstalk before.
    Where can i find the logs of 3CX Phone client?
    Here is the log from the Expresstalk. Not sure if it helps something or not:
    10:10:54 UDP Packet Sent to 84.21.11.253:5060 >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
    REGISTER sip:MY-VOIP-PROVIDER SIP/2.0
    Via: SIP/2.0/UDP MY-STATIC-IP:31722;rport;branch=z9hG4bK03744
    Max-Forwards: 20
    To: <sip:OWN-NUMBER@MY-VOIP-PROVIDER>
    Call-ID: 1351066254-3744-PROBOOK4525-@192.168.0.100
    CSeq: 2 REGISTER
    Contact: <sip:OWN-NUMBER@MY-STATIC-IP:31722>;expires=3600;q=0.90
    User-Agent: NCH Software Express Talk 4.18
    Content-Length: 0
    10:10:54 UDP Packet Received from 84.21.11.253:5060 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    SIP/2.0 401 Unauthorized
    Via: SIP/2.0/UDP 192.168.0.100:5070;rport=31722;branch=z9hG4bK03744;received=MY-STATIC-IP
    To: <sip:OWN-NUMBER@MY-VOIP-PROVIDER>;tag=5442bb4a1db211e2bd7800145e2b06f4
    CSeq: 2 REGISTER
    WWW-Authenticate: Digest realm="sip3.voipexchange.hu", nonce="5442b8341db211e2bd7800145e2b06f4"
    Server: MERA MVTS3G v.4.3.0-33a
    Content-Length: 0
    Via: SIP/2.0/UDP MY-STATIC-IP:31722;rport;branch=z9hG4bK13744
    Max-Forwards: 20
    CSeq: 3 REGISTER
    Authorization: Digest username="OWN-NUMBER",realm="sip3.voipexchange.hu",nonce="5442b8341db211e2bd7800145e2b06f4",uri="sip:MY-VOIP-PROVIDER",response="86c1fa6829328d9a85feddfd4bea055e",opaque="",algorithm=MD5
    Content-Length: 0
    SIP/2.0 200 Ok
    Via: SIP/2.0/UDP 192.168.0.100:5070;rport=31722;branch=z9hG4bK13744;received=MY-STATIC-IP
    To: <sip:OWN-NUMBER@MY-VOIP-PROVIDER>;tag=544b9f441db211e2bd7800145e2b06f4
    CSeq: 3 REGISTER
    Contact: <sip:OWN-NUMBER@192.168.0.100:5070>;q=0.90
    Expires: 60
    Content-Length: 0
    10:11:06 UDP Packet Sent to 84.21.11.253:5060 >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
    INVITE sip:DIALED-NUMBER@MY-VOIP-PROVIDER SIP/2.0
    Via: SIP/2.0/UDP MY-STATIC-IP:31722;rport;branch=z9hG4bK23744
    To: <sip:DIALED-NUMBER@MY-VOIP-PROVIDER>
    From: "xxx" <sip:OWN-NUMBER@MY-VOIP-PROVIDER>;tag=2720
    Call-ID: 1351066255-3744-PROBOOK4525-@MY-STATIC-IP
    CSeq: 920 INVITE
    Max-Forwards: 20
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, INFO, REFER, NOTIFY
    Supported: replaces
    Content-Type: application/sdp
    Content-Length: 383
    v=0
    o=NCHSoftware-Talk 1351066254 1351066255 IN IP4 MY-STATIC-IP
    s=Express Talk Call
    c=IN IP4 MY-STATIC-IP
    t=0 0
    m=audio 8000 RTP/AVP 0 8 96 3 13 101
    a=rtpmap:0 PCMU/8000
    a=rtpmap:8 PCMA/8000
    a=rtpmap:96 G726-32/8000
    a=rtpmap:3 GSM/8000
    a=rtpmap:13 CN/8000
    a=rtpmap:101 telephone-event/8000
    a=fmtp:101 0-16
    a=sendrecv
    a=local:192.168.0.100 8000
    a=domain:MY-STATIC-IP
    10:11:06 UDP Packet Received from 84.21.11.253:5060 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    SIP/2.0 100 Trying
    Via: SIP/2.0/UDP 192.168.0.100:5070;rport=31722;branch=z9hG4bK23744;received=MY-STATIC-IP
    CSeq: 920 INVITE
    Contact: <sip:DIALED-NUMBER@84.21.11.253:5060>
    Content-Length: 0
    10:11:11 UDP Packet Received from 84.21.11.253:5060 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    SIP/2.0 180 Ringing
    To: <sip:DIALED-NUMBER@MY-VOIP-PROVIDER>;tag=1381644891-3792810525-335577277-4094045022
    CSeq: 920 INVITE
    Content-Length: 173
    v=0
    o=- 1351066270 1351066270 IN IP4 84.21.11.253
    s=-
    c=IN IP4 84.21.11.253
    t=0 0
    m=audio 17996 RTP/AVP 8
    a=sendrecv
    a=silenceSupp:eek:ff - - - -
    10:11:16 UDP Packet Sent to 84.21.11.253:5060 >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
    CANCEL sip:DIALED-NUMBER@MY-VOIP-PROVIDER SIP/2.0
    CSeq: 920 CANCEL
    Max-Forwards: 20
    Content-Length: 0
    10:11:16 UDP Packet Received from 84.21.11.253:5060 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    SIP/2.0 200 OK
    CSeq: 920 CANCEL
    Content-Length: 0
    SIP/2.0 487 Request Terminated
    CSeq: 920 INVITE
    Reason: SIP;cause=487;text="Request Terminated"
    Content-Length: 0
    ACK sip:DIALED-NUMBER@MY-VOIP-PROVIDER SIP/2.0
    CSeq: 920 ACK
    Max-Forwards: 20
    Content-Length: 0
    10:11:23 UDP Packet Sent to 84.21.11.253:5060 >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
    Via: SIP/2.0/UDP MY-STATIC-IP:31722;rport;branch=z9hG4bK33744
    Max-Forwards: 20
    CSeq: 4 REGISTER
    Contact: <sip:OWN-NUMBER@MY-STATIC-IP:31722>;expires=0;q=0.90
    Content-Length: 0
    10:11:23 UDP Packet Received from 84.21.11.253:5060 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    SIP/2.0 200 Ok
    Via: SIP/2.0/UDP 192.168.0.100:5070;rport=31722;branch=z9hG4bK33744;received=MY-STATIC-IP
    To: <sip:OWN-NUMBER@MY-VOIP-PROVIDER>;tag=659193581db211e2bd8f00145e2b06f4
    CSeq: 4 REGISTER
    Contact: <sip:OWN-NUMBER@192.168.0.100:5070>;expires=0;q=0.90
    Expires: 0
    Content-Length: 0
  12. gergely
    Oct 22, 2012
    9
    any idea guys? :idea:
  13. lneblett
    Sep 7, 2010
    2,061
    56
    The logs from the softphone you use, do not have enough info. We need to see the 3cx logs.
  14. gergely
    Oct 22, 2012
    9
    Where can i find the 3CX Phone client logs?
  15. lneblett
    Sep 7, 2010
    2,061
    56
    Not the softphone, but the 3CX system logs.
  16. leejor
    10,374
    231
    How about...who is your VoIP provider, what URL do you register to?
    When I do a search on the IP, it points to something in Hungary?, but nothing beyond that.
  17. gergely
    Oct 22, 2012
    9
    Provider: http://voipshop.hu/
    Their server: sip.voipshop.hu
  18. leejor
    10,374
    231
    If it were me, I would push them for some more information about the message that you are getting back from them.
    It's obviously getting to them. They just need to tell you why they have a problem with it.
