No outgoing SIP call from nokia E60, incoming ok
Discussion in '3CX Phone System - General' started by bozzy2007, Oct 1, 2007.
  1. bozzy2007
    Sep 30, 2007
    Here is my setup:
    3CX Phone System Version3.1.2434.0 (192.168.1.10)
    Linksys SPA 3102 (192.168.1.4)
    Softphones
    Nokia E60 (192.168.1.15)
    All registered with 3CX and i can make internal and external calls from all softphones, and i can call TO nokia E60 (ext 103).
    But i can NOT call FROM the E60
    When i try to make a "internet call" from the E60, the phone says "internet service not available" or "the address is not in use"
    depending on settings under "Manage Gateways & Providers" in 3CX
    3cx log file:
    Code:
    22:57:13.171 Endpoint::findSource [CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '192.168.1.15'; From: 'thisis'; To: '102'; Rline: '102'; Contact: '103' 22:56:23.171 AuthMgr::onAuthFailure [CM101000] Registration request
    from sip:thisis@anonymous.invalid failed. Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    I know the SIP client in E60 is lousy, but i once had it to work with an external voip provider (musimi-denmark)
    Any help appreciated :wink:
    Jesper Clausen, Denmark
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    I believe this will help and if it does, I spent many sleepless nights finding this one line solution :cry:
    From Admin page >> Manage Ext >> Click Ext number >> Click Other Options >> Enter "103" in SIP ID field >> Click OK >> Enjoy (I hope) :lol:
    I am assuming I am right and "103" is the Nokia.
