No Pin (pinless) Voicemail Access from Ext
Discussion in '3CX Phone System - General' started by Trimline, Mar 20, 2011.
  1. Trimline
    Mar 10, 2011
    14
    I am attempting to set one of my extensions to a no pin (no pin required), voicemail access. In the *.ini I have set the vmpinrequired to both 0 and to 1 and this does not work - http://www.3cx.com/forums/voicemail-auto-logon-16938.html
    On the extension definition, it does not permit me to save the extension without a least one digit.
    Does anyone know a way to circumvent this?
    This is a small mini license system for SOHO use.
  2. Trimline
    Mar 10, 2011
    14
    Got to work, I just set 0 via advanced vm* options. Had to let it register the extensions and it works just fine.
