No Play store
Discussion in 'Android' started by amygoda, Oct 31, 2013.
  1. amygoda
    amygoda Member
    Sep 18, 2006
    436
    No Play store or Android market on my tab
    Is there a way to download 3CX for android directly?
    Thank you
    10,586
    252
    The APX files have been available from time to time, but you haven't specified which one you are looking for. Having a device that doesn't not have access to Google Play pretty much guarantees that no version hasn't been tested on your device (or will work at all), so, if it doesn't work, you are probably "on your own".
  3. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hi Leejor,
    Thank you for your reply
    ok good news, can you send the links for v12 & 11
