No presense
Discussion in 'Android' started by brightstar, Jun 9, 2017.
  1. brightstar
    Oct 22, 2015
    6
    The latest android client isn't showing presence info and on investigation it appears to be trying to talk to the PBX on port 80 however the PBX has always used 5000 for HTTP
    It registers fine, and calls are fine, but no presence or phonebook, etc.
    State table on the firewall is filling up with:
    tcp 192.168.xxx.xx:xxxxx -> 192.168.xxx.xx:80 TIME_WAIT:TIME_WAIT
    Which is how I know it's trying to use the wrong port!
  2. imagemaster
    Jul 20, 2010
    46
    I am having the same issue. No presence or phonebook but call in and out are fine.
  3. imagemaster
    Jul 20, 2010
    46
    In hind sight it seems simple but you changed the connection from 80/443 to 5000/5001. You did not update your firewall configuration documentation. Once I added the two new ports, everything works fine.
