No provision link with cloned template - v15.5
Discussion in '3CX Phone System - General' started by R22, Mar 6, 2018.
  1. R22
    R22
    Jan 11, 2018
    7
    Hi All,
    I have been struggling a bit now. I need to modify a logo on a yealink T21P E2 phones.
    So I cloned a template and renamed and saved. I did not modified any contents yet, restarted the 3cx windows server and tried to add a phone with this new template.
    Doing so, the provision link was blank as per below
    Provisioning Link: Not available -
    Any ideas what might I am doing wrong
    Thanks in advance
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Why not just change the logo on the server side? perhaps not an option... and would require changing every update probably - but template would still be officially supported.
    --> Is the phone listed in the dropdown on the extension still with the correct Mac Address? The provisioning link never changes... its always the same.
  3. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    #3 Saqqara, Mar 6, 2018
    YiannisH_3CX likes this.
  4. R22
    R22
    Jan 11, 2018
    7
    Hi again,
    Managed to provision the phones with the new templates. I was selecting the standalone template the yealinkT21P instead of the yealinkT4x.
    Now I am trying to figure out where to save my new custom logo for the phones.
    Do I have to leave a TFTP server running on the 3CX server ?
    Thanks in advance
