No Ring on Push v14
Discussion in 'Android' started by daktur, Dec 17, 2015.
  1. daktur
    daktur New Member
    Oct 15, 2015
    230
    8
    I am facing the same no ring issue on v14. When my android app is awating for push notification, the phone does note ring and android shows the notification only after a while as a missed call.
    Any ideas?
    Thank you
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,386
    88
    Make sure you have PUSH enabled for that extension in the Extension Settings for that extension.
    If that doesn't work, try deleting the account from the Android App and sending a new Welcome Email.
    If that also doesn't work, I have seen cases where deleting the GCM project and recreating it with a new API key, etc fixed this issue. If you do this remember to send a new Welcome Email again after deleting the account on the phone first.
    Just in case you need the instructions of how to create a GCM Project have a look here:
    http://www.3cx.com/docs/configuring-google-push/
