No Ring on Windows Softphone
Walter Tokich
I just installed the 3CX softphone on my PC and when I call it I get a visual alert to the incoming call but no audible ringtone.
I'm a newbie so I appreciate the help.
Walter
If this is a new installation of the client and you haven't tried swapping Wav files for ringtone.wav then I think chances are you need to check local settings on the PC.
For example check the client under - Settings (cog icon) - audio and take a look at the default devices. Is it set to local PC or a headset?
Also more basic settings like the audio on the PC itself and default audio device.
Thanks for the reply. Well it just started working without me doing anything. Now I need to figure out why I can't make outbound calls.
Get 3CX - Absolutely Free!
3CX
