No Ring or Hold Music on Blind Transfer (bxfer) for SPA942
Discussion in '3CX Phone System - General' started by jjspyder, Jan 9, 2009.
  1. jjspyder
    Jan 9, 2009
    6
    I have Linksys SPA942 phones and I am having a problem with calllers not hearing a ring or hold music after performing a blind transfer. The blind transfer still works, but it's a problem because callers don't hear anything and sometimes think they have been disconnected. I am using the latest firmware for the SPA942 phones and I am using the last version 6 of the 3cx phone system. I am considering upgrading to 3CX version 7. Does anyone know how to fix this problem or if the problem is still there with 3CX version 7. Thanks.
    Jason
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    You may be able to resolve this by toggling one of these three options for the extension in question:
    1. Supports "Replaces"
    2. Supports "Reinvites"
    3. PBX delivers audio
    I suggest trying in this order (with the most preferable at the top):
    • PBX delivers Audio OFF, Reinvites ON, Replaces ON
    • PBX delivers Audio OFF, Reinvites ON, Replaces OFF
    • PBX delivers Audio OFF, Reinvites OFF, Replaces OFF
    • PBX delivers Audio ON, Reinvites ON, Replaces ON
    • PBX delivers Audio ON, Reinvites ON, Replaces OFF
    • PBX delivers Audio ON, Reinvites OFF, Replaces OFF
    Hope this helps.
    Regards
    Kevin
  3. jjspyder
    Jan 9, 2009
    6
    Thanks for your suggestions. However, I tried every combination with no luck. The caller still hears silence when using blind transfer (bxfer). The callers hear hold music when I use regular attended transfer (xfer). I just can't figure out why the phones behave like this. Do you think the problem is with the phones or the 3CX system? Thanks.
    Jason
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    It's practically definitely a phone issue. I would suggest you contact LinkSys support for assistance - maybe they can shed some light on the matter.
    Regards
    Kevin
  5. loowee
    Nov 20, 2009
    24
    Re: No Ring or Hold Music on Blind Transfer (bxfer) for SPA9
    Any insight on this issue JJSpider ?
    We have hotel clients mentionning the problem as well, they say they lose 1/2 the callees when using BXFER because of the dead silence while remote phone is ringing.
    Keep in touch ! Thx...
