no ring played to callers
Discussion in '3CX Phone System - General' started by jeremyn, Jun 26, 2008.
  1. jeremyn
    Mar 25, 2008
    42
    hi all,
    I have an external line setup which rings the ext fine, however the caller hears no ringing, but they can hear when it's answerd, any suggetions ?
    thanks
  2. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    You need to give us a little more info here.
    Is the external line a SIP trunk or PSTN through a gateway? If so what gateway? Log files would be good too.
    It is a good idea to follow NG's guidelines for help, these can be found here http://www.3cx.com/forums/forum-rules---read-to-get-answers-93.html
  3. jeremyn
    Mar 25, 2008
    42
    please ignore as I have been told we have a support account and will be lodging a support ticket
  4. matfalci
    Apr 24, 2008
    27
    I have the same problem when i call form a SIP provider...
