No RTP from CSipSimple
Discussion in '3CX Phone System - General' started by 3cxisti, Feb 7, 2013.
  1. 3cxisti
    Dec 11, 2012
    24
    Hallo,
    we use on Android CSipSimple together with 3CX Free.
    For some Days we have the following error:
    07-Feb-2013 09:58:04.341 [MS105000] C:68.1: No RTP packets were received:remoteAddr=0.0.0.0:0,extAddr=0.0.0.0:0,localAddr=178.77.69.XX:9010
    07-Feb-2013 09:58:03.645 Leg L:68.2[Line:10001>>0721601XXXX] is terminated: Cause: 487 Request Terminated/INVITE from 217.10.79.9:5060
    07-Feb-2013 09:58:03.518 [CM503008]: Call(C:68): Call is terminated
    07-Feb-2013 09:58:03.518 Leg L:68.1[Extn] is terminated: Cause: CANCEL from 89.204.XXX.XX:61192
    07-Feb-2013 09:58:02.720 [CM505003]: Provider:[Sipgate 56048XXX] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:29010XXXX@178.77.XX.XX:5060]
    07-Feb-2013 0
    Has somebody an Idea what to do?
    I have already try to change settings "Anlage überträgt audio" (PBX forwards audio) or "supports "Replace Header" etc.
    The extension cannot give a call and cannot receive a call (with the same error).
    Thank you for your help.
    With kind regards
    I.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    One cause could be if there is more than one network card installed. You most likely need to run wireshark so you can see if and where any rtp packets are being sent.
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    have you set stun server in c sip simple, if using the phone in another network than the 3CX server ?
