gizmo when calling out on gizmo
Same Issue
ext
Clear
Time Message
17:09:42.437
Currently active calls [none]
17:09:12.406
17:08:42.296
17:08:11.921
17:07:39.921
17:07:09.750
17:07:01.421
[CM506001]: STUN request to resolve SIP external IP
ort mapping is sent to STUN server 198.65.166.165:3478 over Transport 192.168.163.75:5060
17:06:39.328
17:06:09.187
17:05:39.125
17:05:08.921
17:04:38.750
17:04:14.609
[MS105000] C:24.2: No RTP packets were received:remoteAddr=130.94.88.94:16736,extAddr=0.0.0.0:0,localAddr=192.168.163.75:7110
17:04:13.515
[CM503008]: Call(24): Call is terminated
17:04:08.671
Currently active calls - 1: [24]
17:04:07.562
Session 25703 of leg C:24.1 is confirmed
17:04:07.484
[CM503007]: Call(24): Device joined: sip:
[email protected]:5060
17:04:07.421
[email protected]:60126;rinstance=eca5c3dee0aa92af
17:04:07.406
[MS210003] C:24.1:Answer provided. Connection(transcoding mode[unsecure]):192.168.163.75:7108(7109)
17:04:07.406
[MS210001] C:24.2:Answer received. RTP connection[unsecure]: 130.94.88.94:16736(16737)
17:04:07.390
Remote SDP is set for legC:24.2
17:04:07.390
[CM505003]: Provider:[Gizmo 17472721772] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:
[email protected]:5060]
17:04:07.390
[CM503002]: Call(24): Alerting sip:
17:04:06.937
[CM503025]: Call(24): Calling VoIPline:18005551212@(Ln.10009@Gizmo 17472721772)@[Dev:sip:
17:04:06.937
[MS210002] C:24.2:Offer provided. Connection(transcoding mode): 192.168.163.75:7110(7111)
17:04:06.875
[CM503004]: Call(24): Route 1: VoIPline:18005551212@(Ln.10009@Gizmo 17472721772)@[Dev:sip:
17:04:06.843
[CM503010]: Making route(s) to <sip:
[email protected]:5060>
17:04:06.843
[MS210000] C:24.1:Offer received. RTP connection: 192.168.163.190:40024(40025)
17:04:06.843
Remote SDP is set for legC:24.1
17:04:06.828
[CM505001]: Ext.14: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone 5.0.14900.0] PBX contact: [sip:
17:04:06.796
[CM503001]: Call(24): Incoming call from Ext.14 to <sip:
17:04:06.781
[CM500002]: Info on incoming INVITE:
INVITE sip:
[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.163.190:60126;branch=z9hG4bK-d8754z-4535bf0b065fa936-1---d8754z-;rport=60126
Max-Forwards: 70
Contact: <sip:
[email protected]:60126;rinstance=eca5c3dee0aa92af>
To: <sip:
[email protected]:5060>;tag=ab6ad927
Call-ID: ODRhZmViOGFmOTU3ZmFhNjcyY2VkNDgwYmMzYTk2MGM.
CSeq: 2 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE
Proxy-Authorization: Digest username="14",realm="3CXPhoneSystem",nonce="414d535c0367bf0678:005e4ad6246c90f4b2620924f8a53ee2",uri="sip:
[email protected]:5060",response="45483d78cdc3f4443aa4278ca95925d6",algorithm=MD5
Supported: replaces
User-Agent: 3CXPhone 5.0.14900.0
Content-Length: 0
17:04:06.015
