No RTP Packets on Linksys SPA941 external extension
Discussion in '3CX Phone System - General' started by Sirk, Oct 2, 2008.
  1. Sirk
    Sep 26, 2008
    12
    Hi Guys,
    I setup an external extension on our SPA941 connecting to our 3CX IP PBX. It connected to our 3CX but the problem is when external extension calls our internal extension, I can hear the voice of our external ext but the caller cannot hear my voice. And I cannot dial our external extension from our internal ext. Also on the Phone Status under SIP tab on our SPA941 external ext has no RTP Packets detected.
    Anybody can help please?
    Thanks!
  2. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    Try to use the 3CX client as the external extension and see if the same issue remains or if it works.
    Please also ensure that on the external extension settings, you have enabled the STUN server option.
    regards
  3. galal202
    galal202 New Member
    Jun 23, 2008
    235
    use stun server
    I prefer fwd stun
  4. tekknow
    Oct 3, 2008
    29
    This sounds much like the problem that I posted here
    http://www.3cx.com/forums/nated-ua-rtp-packets-go-to-lan-ip-7378.html
    I suggest that you do an ethereal capture from the 3cx machine to find out if it too is sending RTP to the (non routable)Private LAN IP . I am beginning to believe this is a bug in the resolution of IPs in 3cx, but I am looking for additional proof.
    Of course it is probable that the LInksys and Cisco behave very similarly because Linksys is owned by Cisco
