No RTP Packets received on Inbound Calls
Discussion in '3CX Phone System - General' started by RUAN MALAN, Jun 28, 2007.
  1. RUAN MALAN
    Jun 28, 2007
    I have a problem where we dial into a VOIP number, the call gets connected and shos on the server logs, but there is no audio and when the phonecall is ended the message "No RTP packet recieved from IP address 196.46.138.18 (Our VoIP providers RTP server). The VoIP provider analyzed the call and says the 3cx pbx is not replying on its INVITE. Any ideas?
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Please specify your VoIP provider.
    Thanks,
    Stepan
  3. Anonymous
    Anonymous Guest
    Have you tried setting up the stun server?
    also make sure your firewall is not filtering your RTP packets?
    Bind to media server and or extension is externa.
