Solved No selectable options for MCU when configuring webmeeting
Discussion in '3CX Phone System - General' started by Marari, Feb 15, 2018.
  1. Marari
    Marari New Member
    Sep 16, 2007
    123
    21
    Version 15.5
    [​IMG]
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @Marari
    Please make sure that port 5001 is open on your firewall so that the phone system can communicate with the webmeeting servers and try again. You also try clearing your browser cache and see if that helps.
  3. Marari
    Marari New Member
    Sep 16, 2007
    123
    21
    I wound up doing a backup, reinstall, restore. It works now.
  4. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Glad to see the issue has been resolved and thank you for sharing your solution
