No Sound at client when using nat
Discussion in '3CX Phone System - General' started by jvwelzen, Aug 23, 2008.
  1. jvwelzen
    Jun 9, 2008
    8
    Hi There
    Does anyone know why I get nog Sound At Client side when using nat..
    My sister has a kabel provider with a fixed ip adress and everything works
    but when I am at my dad's house I don't get any sound on the softphone.
    My dad has a speedtouch with full cone nat any idee if I have to open some ports here to
  2. galal202
    galal202 New Member
    Jun 23, 2008
    235
    open ports 5060,5080,9000
  3. jvwelzen
    Jun 9, 2008
    8
    The ports are open but i still does'n work
    do we ned to open some ports at the client side also ??
    do we need to op some higer ports like 10000-20000 /40000-50000
