No sound when paging
Discussion in '3CX Phone System - General' started by jazd, Mar 9, 2011.
  1. jazd
    Mar 9, 2011
    I have a server running 3CX Mini Edition and it has a paging group setup with 4 extensions in it. The paging group is using SIP not multicast.
    The 4 extensions are Cyberdata v2 paging amplifiers, the phone being used to call the paging group is a Aastra 6755i.
    When I call the paging group the Cyberdata units beep indicating that they received a call but then they dont play the call audio over the speakers. If I just call a single extension they work fine.
    Does anyone have any idea's why they would work OK when calling a single extension and not the paging group? When I only had 2 of the extensions added it was working but now I've added all 4 extensions I'm getting nothing even if I remove the other extensions again.
    11,093
    327
    3CX log?
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Cyberdata v2 paging amplifiers have never been tested by 3cx, i recommend you do a wireshark capture and identify if RTP stream is going to all these amplifiers, also make sure the sip exchange is correct.
    Furthermore try and connect a 5th phone, a 3cx voip phone see how that works.
  4. jazd
    Mar 9, 2011
    Thanks for the suggestions I will do a big of digging and report back.
