No status lights for extensions or Trunks
Discussion in '3CX Phone System - General' started by mazingtree, Oct 15, 2016.
  1. mazingtree
    Oct 13, 2011
    10
    I've just installed V15 as a long time user and I'm dismayed by the loss of the Status lights on the extensions and SIP trunks - all I see is a fixed green 'led' for the registered extensions, but they used to turn yellow when in use.
    How can we easily see whether a system is in use and which extensions are in calls etc. It's one of the really neat features to be able to see instantly whether calls are in progress.
    Perhaps I have a problem, but tried IE and Chrome. Does anyone else see the same?
  2. creative3
    Sep 21, 2010
    15
    12
    This is a good feature and would be great to see it back in v15
