No Sync of ODBC / LDAP - Support me!
Discussion in 'Ideas' started by narkumas, Apr 11, 2017.
Do You agree? Want to support this feature request?
  1. Yes! That's simple and cool!
    100.0%
  2. No, What a sh***
    0 vote(s)
    0.0%
  1. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    29
    I have thought about ODBC and LDAP replication as it is now.
    - It does not work properly: Double entries are created all the time
    - It does not sync. Deleted records in the source will not be deleted in the Phonebook
    I do suggest that the source database (ODBC and LDAP) holds the most actual contact information. Therefor it is not necessary to make a sync. It is sufficient to delete all ODBC/LDAP-phonebook entries and replace them with the source data once a night. A "sync now" button for the admin would be ok too.
    I guess this would be not more than 10 minutes work for a developer since the replication code already exists..
    come on! make us happy!
    cheers
    Marius
    #1 narkumas, Apr 11, 2017
