No talk path
Discussion in '3CX Phone System - General' started by lonestar.computer, Mar 14, 2008.
  1. lonestar.computer
    Jan 27, 2008
    16
    I installed a new system with the latest version from the download site. Everything tests OK on the firewall tests OK :
    1 9000 Information (9) Port is open and can be used for calls. externalAddress = 68.113.xx:9000
    2 9001 Information (9) Port is open and can be used for calls. externalAddress = 68.113.xx:9001
    3 9002 Information (9) Port is open and can be used for calls. externalAddress = 68.113.xx:9002
    4 9003 Information (9) Port is open and can be used for calls. externalAddress = 68.113.xx:9003
    5 9004 Information (9) Port is open and can be used for calls. externalAddress = 68.113.xx:9004
    6 9005 Information (9) Port is open and can be used for calls. externalAddress = 68.113.xx:9005
    7 9006 Information (9) Port is open and can be used for calls. externalAddress = 68.113.xx:9006
    (Actual IP not shown)
    The VOIP is Broadvox. The SIP link is registering OK.
    I can send and RX calls with no problem.
    The problem is that there is no speech path so neither the calling or called party can hear each other.
    The local system firewall is suspected but it is configured OFF.
    Help please.
  2. LORD ORION
    Jul 23, 2007
    39
    If you are behind a router, try forwarding RTP ports to the specific machine.
