Solved No "Templates" under Settings
Discussion in '3CX Phone System - General' started by JF007, Mar 4, 2018.
  1. JF007
    Mar 4, 2018
    16
    Hello everyone,
    I'm trying to edit the template for a Yealink T46S to customize settings as I learned that the phone re-provisioning overwrites all the changes I made directly through the phone web UI. Every single reference I've found online tells me to go to Management Console > Settings > Templates. The problem is that "Templates" is NOT under settings. Not sure if this was a recent update or if I'm missing something. The edition comparison chart does not show this as a difference. Please help!
    Thanks.
  2. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    841
    125
    Try another browser, clear your cache
    Not heard of this issue before
  3. JF007
    Mar 4, 2018
    16
    Thanks for your response Saqqara. I tried clearing the cache. Also tried Chrome, Firefox and Safari on Mac and Chrome, Firefox, IE and Edge on Windows. Still no "Templates" under "Settings".
  4. JF007
    Mar 4, 2018
    16
    Also, I won't let me edit the template file when I open it by clicking "+ Config" when selecting the phone under "Phones"
  5. Saqqara
    Mar 12, 2014
    841
    125
    This option shows the template pushed out to the phone, does not allow you to edit it
  6. JF007
    Mar 4, 2018
    16
    That makes sense. Thanks.
    I'll reboot the server to see if that helps somehow. Still no "Templates"
  7. Saqqara
    Mar 12, 2014
    841
    125
    What version of 3CX ?
    Windows or Debian ?
  8. JF007
    Mar 4, 2018
    16
    It is the free cloud. Every indication is that it's a linux VM. If I run updates it says that it is up to date, so it's the latest. I believe 15.5 Update 3.
  9. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Are you logged in as the Admin user?
    Please note: Lesser users don't see all things. Operator extension may not see them as well. Login as a user and not an extension.
  10. JF007
    Mar 4, 2018
    16
    Yes, I am logged in as admin.
  11. eddv123
    eddv123 Active Member
    Aug 15, 2017
    873
    131
    Can I confirm one thing with you as it sounds like a similar problem I have known some re-sellers to have.
    If you go into "Settings" and "Templates" can you actually access the Templates screen ? so is the issue that the templates simply do not display in the drop down box.
    The issue I am talking about is normally due to insufficient resources, or you are connecting remotely to a 3CX instance with poor internet.
    The templates do appear if you wait a little longer for them to load - due to the above reasons it just takes a while for them to load up.
  12. JF007
    Mar 4, 2018
    16
    I wonder what else I’m missing. Here’s what I see
    - 3CX Client
    - Blacklisted Numbers
    - Call Parking
    - CDR
    - Conferencing
    - CRM Integration
    - Dial Codes
    - E164 Processing
    - Email
    - Fax Server
    - MOH
    - Timezone...
    - PBX
    - Security
    - System Prompts
    - Voicemail
    - Hotel Services
  13. JF007
    Mar 4, 2018
    16
    Thanks for your reply.
    When I go to “Settings” I do not see “Templates”. I only see the 17 options listed in my previous post.
  14. eddv123
    Aug 15, 2017
    873
    131
    If that is the case then the only things I could think of that would effect this have already been suggested.
    You have a 3CX edition that does not support "custom templates" (however the edition comparison table confirms that this is not the case): https://www.3cx.com/phone-system/edition-comparison/
    Or that you have insufficient privileges in the management console. Although there is not an exact setting to deny access to these templates, under System management there is a setting for "General System Administration" which does not list exactly what this entails.
  15. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    You're also missing license, Music on Hold. Sure looks like you are not a full administrator.
    There are 20 options.
    Go into security/admin credentials and verify you are the user listed there.
    This is 15.5 version?
  16. JF007
    Mar 4, 2018
    16
    Jimbo,
    I agree admin rights seems to be the most plausible cause given the scenario. I went to Security > Admin Credentials and the account is certainly the one I'm using.
    I wonder if running hosting this in the cloud has anything to do with the level of access I have.
    Yes, I am running 15.5
  17. JF007
    Mar 4, 2018
    16
    I do have Music on Hold. I must be missing something else as I only have 17.
  18. JF007
    Mar 4, 2018
    16
    I signed up for a free year of cloud hosted 3CX. I got a username, pw, URL, etc. to log in. When I log in as admin I see 17 items in "Settings" I do not see Licensing or Templates.
    I'm incredibly frustrated. I'm about to give up on 3CX. I thought I had found the perfect system for my needs.
  19. JF007
    Mar 4, 2018
    16
    I'm also missing "Parameters". If I am using THE admin account that was provided to me to log into the web console, how do I get access to the missing options? Any help would be greatly appreciated.
  20. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Wait until tomorrow when the 3CX team can help you. It makes no sense if you are logged in as admin you have limited rights. But this may be just a dream.
