- Joined
- Nov 23, 2007
- Messages
- 43
- Reaction score
- 0
Hi, not sure whether I've done something wrong, but after a re-installation of the VOIP client I don't have the tunnel configuration options available anymore.
With a recent installation I had some problems, and killed both the voip client process, as well as the tunnel process. After this I re-installed. Now just tried to install 5.0.4034, but aagain no tunnel option.
Settings screen shows the Ports, Stun, DTMF and Codecs tab, but no tunnel.
Is version 5.0.4034 without tunnel, or is my installation corrupt ?
How can I do an installation from scratch again. Is it need to remove config files, or registry entries ?
Thanks,
Arnaud
Thanks,
Arnaud
