Solved No updates for 15.5 sp3
Discussion in '3CX Phone System - General' started by Michael Groom, Feb 23, 2018.
  1. Michael Groom
    Dec 11, 2017
    63
    I have a linux distro setup through pbx express running 15.5 sp 2 but it tells me my system is up to date, even though i know sp3 is out.
    I have tried to ssh in and run these commands
    sudo echo "deb https://downloads.3cx.com/downloads/3cxpbx/ /" | sudo tee /etc/apt/sources.list.d/3cxpbx.list
    sudo apt-get update
    as per the instructions in the blog but still will not show me that sp3 is available.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,248
    202
  3. Michael Groom
    Dec 11, 2017
    63
    I tried that and still no updates available
  4. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    77
    Try changing to http instead of https.
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,320
    531
    Hello @Michael Groom
    Can you correctly resolve downloads.3cx.com from the 3CX server? Also navigate to Settings / Downloads and search for "DOWNLOADS_URL". What is the link in the value section?
  6. Michael Groom
    Dec 11, 2017
    63
  7. Michael Groom
    Dec 11, 2017
    63
    It is now showing that sp3 beta is available but still not SP3 release
  8. YiannisH_3CX
    May 10, 2016
    7,320
    531
    Please check your inbox as i have sent you a p.m with what we will need to further troubleshoot your issue.
  9. YiannisH_3CX
    May 10, 2016
    7,320
    531
    For anyone else that might face the same issue, the problem was that there was a typo in the
    /etc/apt/sources.list.d/3cxpbx.list which caused the update not to display correctly. Once it was corrected the SP3 update was available for download in the management console
  10. AGidi
    Jun 30, 2017
    49
    6
    Hello, im in a similar boat. It shows im updated to 15.5.0 on our NFR, our client´s installs did auto update correctly. This happened before with the hotdesking update, it did not whos either, but got support and updated. I cant remember what we did then. please advice.
  11. YiannisH_3CX
    May 10, 2016
    7,320
    531
    Exactly what is the issue? What version are you currently running? Are you seeing an update in the management console? If so is it the correct update? Are you running windows or linux?
