- Joined
- Jul 29, 2017
- Messages
- 2
- Reaction score
- 0
At the moment I am in Egypt, when I want to make a call the voice drops after 2 seconds, I can hear the answer and then nothing. Is the a solution for this?
Peter
Peter
You haven't really provided a lot of information.
Is the PBX located in Egypt, or are you attempting to use a remote extension/softphone there? Is this problem only encountered in Egypt? What provider are you using? Have you tried enabling the Tunnel feature?
I know some Middle-East countries block VoIP, but I'm not certain if Egypt is one of them.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
